What hand pump for diff fluid?
I am lazy and uncoordinated. Every time I swap out diff fluid, I swear i will never do it again. There has to be a better way. I have a little hand siphon with about a 1/4 inch tubing. Takes forever. Can anyone point to a make and model of a hand pump that will get the job done easier and faster?
Just buy the quart bottles and squirt it in:idea: If its to thick you can always put it in the microwave and thin it with heat.
I always stick the quart bottles in a bucket of HOT water and use a tube to fill from above.
Yep, those quart bottles make a huge mess. Buy the 90W in 5 gal buckets, and get a bucket pump, they sell them at NAPA and other places. MUCH MUCH easier.
autozone and Napa both have $10 hand pumps that thread into the gallon size jug openings. Ive got an old gallon jug from when i swapped all the fluids i reuse by pouring the 3.2 qts into it and pumping away.
Diffs arent too bad to fill straight from the bottle but the tcase sux. The clear tubing makes it even easier w/ the pump.
my pump is stamped performance products and is from NAPA.
I've got something like that, it threads on a quart bottle and has a clear hose attatched to the nozzle. The bottle stays on the ground while I pump with one hand, and hold the hose in the fill port with the other hand. It was about $5.
