My mantra is: "Life is to short to sit in repair shops" %)Life is too short to be running stock wheels![]()
I honestly love my stock Limited rims. Oddly, they were the same ones I was tracking down for my 100 Series. I am on the fence on keeping them or moving to a set of Method 305 (17ā) bronze/black lip.Life is too short to be running stock wheels![]()
this is defintely a side effect of re-gearing nobody talks about. I have noticed this as well with a past build.Anyone familiar with gear install? After removing my mud terrains and installing all terrains I noticed a humming noise coming from the diff/diffs between 30-50mph.
I had 5.29 nitro gears installed back in March and only noticed it sometimes during decelerating, but the tires were so loud I rarely heard anything. Now with the quiet all terrains it's driving me nuts.
I've put close to 10k miles on them and towed/off-road plenty and no issues at all, no vibration, no grinding noise, just humming coming from the diff/diffs. I followed the break-in cycle to a T and did the fluid change with no metal shavings at 500 miles. Maybe its time to go back to mud terrains to block out the noise.
I have it narrowed down to the front passenger wheel bearing. Noise goes away when I turn left every time. Easy fix.this is defintely a side effect of re-gearing nobody talks about. I have noticed this as well with a past build.
Fair pointMy mantra is: "Life is to short to sit in repair shops" %)
Same: I do everything myself. The biggest accomplishments so far are the rebuild of engine and transmission. I lost oomph, though, after doing same sh!t over and over again (it was on a European car, lol). Better spend time on something you never did before, like building a boat, right?Fair point
I will say I never have mine in the repair shop. I do all my own work and do enjoy it. From the sounds of it, itās a damn front wheel bearing and should be an easy fix. Parts show up tomorrow.
If I could do it all over I would have stuck with a +25 or +35 offset. I should have done research and found out that a 0 offset is just too aggressive and the bad wheel bearing is all on me.
Factory steelies stacked!Life is too short to be running stock wheels![]()
I do love the look of stock steelies. I just wish they had a different off set. +60 is tucked in too much for larger tires. +40/+30 would be awesome and I'd run those over anything else.Factory steelies stacked!
Only wheel that makes me look back every even better with a little brake dust.I do love the look of stock steelies. I just wish they had a different off set. +60 is tucked in too much for larger tires. +40/+30 would be awesome and I'd run those over anything else.
That's nice. Unfortunately, the Tundras come in +60+15 OE Yota
Iām awareThat's nice. Unfortunately, the Tundras come in +60![]()
Yuo should get an inferno topper and we will be matchingThis looks like a dumpster fire. What is that inferno with Barcelona? Ayup
Missed leg day 25.4 Bora +34.6
Interrupting the steel wheel dumpster fire with a pic of my trug
View attachment 4201864That looks good!
You should attempt a 37x11.50r18 and see if they clear with those steelies. I love a tall skinny tire look.This looks like a dumpster fire. What is that inferno with Barcelona? Ayup
That Barcelona pro is way more fun to drive with the supercharger and that assembly it only compensate for the parasitic loss with the 37s.You should attempt a 37x11.50r18 and see if they clear with those steelies. I love a tall skinny tire look.
