It works with Andriod also.I've actually been looking for something similar where I could use Android Auto to control OnX, Garmin Power Switch, and add a backup camera. My stereo seems to be too outdated.
I installed a Atoto F7 10" single din. Look into it.I've actually been looking for something similar where I could use Android Auto to control OnX, Garmin Power Switch, and add a backup camera. My stereo seems to be too outdated.
Love that color combo!
Did you have any issues with clearance when using the ATPEAM spring compressor, particularly for the valves in the back for cylinder #6? Do you think you could have used the ATPEAM tool to compress the springs initially to get the keepers out, as well as for reinstalling? I have one of those tools and I'm hoping it will work for the whole job. Thanks.I kept the head on. I used an engine air valve holder to keep the valves in place while I took the spring off. It just keeps the cylinder filled with air while you do the work. Be sure to have a decent size air compressor at hand.
I used a combination of a valve keeper tool to remove the keepers easily. To put them back on, I used a typical valve spring compressor tool. Really wasn’t hard. The keepers are a little finicky and the valve springs are very stout.
Here’s the tools I used.
kweiny Engine Air Valve Holder... Amazon product ASIN B07FYCSKJV
Lisle 36050 Valve Keeper Remover and Installer Kit https://www.amazon.com/dp/B0012S61IO?tag=ihco-20
ATPEAM Overhead Valve Spring Compressor | Universal Automotive Engine Removal Repair Install Tool https://www.amazon.com/dp/B091CRRGD5?tag=ihco-20
I used one like the one pictured in the first post on the original post (not sure why we are now in the what did you do this weekend post?). Only had a clearance issue on the very back spring. I "improvised" using a pry bar on top of the spring retainer and leveraged against the firewall. Worked well enough to get the keepers out with a magnet and 2 extra set of hands.Did you have any issues with clearance when using the ATPEAM spring compressor, particularly for the valves in the back for cylinder #6? Do you think you could have used the ATPEAM tool to compress the springs initially to get the keepers out, as well as for reinstalling? I have one of those tools and I'm hoping it will work for the whole job. Thanks.
Quite under the hood ( well as quite as a 2f can be) and a nice throaty ( not obnoxious ) exhaust coming out the pipe.That must sound terrific.
Is that Part Number R90SS ?Starter solenoid had been acting up off and on for a few weeks and finally was at a point where I decided it was time. The starter for a 2h is a pretty common Denso design used in many applications, and figured out that the solenoid part of it was identical to a Dodge Cummins starter. So I ordered a LarryB's heavy duty starter rebuild kit from Amazon for about $40, which have 90% larger copper contacts, tore it down, cleaned it up, and she's starting perfect again. Here's a few before/after pics:
View attachment 3611015View attachment 3611016View attachment 3611017
Yep, sure is. Amazon actually has it on sale right now for cheaper than I bought it for.Is that Part Number R90SS ?
Thanks for the info. I'll add this to my spares.Yep, sure is. Amazon actually has it on sale right now for cheaper than I bought it for.
LarryB's Starter Solenoid Heavy Duty Rebuild kit for Dodge Cummins Denso 89-2006 https://www.amazon.com/dp/B00D2C1URK?tag=ihco-20
