I still want one.
I still want one.
I have one that will be for sale in the spring. These cars are silly good.I still want one.
And it’s white…. Dang…. Okay. I’ll keep this in mind.I have one that will be for sale in the spring. These cars are silly good.
Did you find a source for the mudflaps that coincide with the flares? That was my only reservation on the flare installGoing to be putting some 80 axles under my truck thanks to @TRAIL TAILOR ... The 80 axles are like 4 or 5 inches wider or so than the 60 axles. I very accurately and professionally installed these flares from australia for mock up to see how theyll look. Hopefully theyll take up some of the extra width the 80 axles are going to give me. These wheels offset will pull them in as much as i can on the axle, so with the flares they should, in theory match up pretty well.
As it sits in the pics, there are 1.25 inch wheel spacers on my wheels because the wheels were bought with specs for the 80 axles that are going in so theyll stick out a little bit further than this. Hopefully not too much further.
They are just white gel coat, they need to be sanded and painted before they can be installed. Sliding cargo windows should be here any day. Just need to find a high roof to graft over and put a turbo in it and i can live my LHD V8 HJ60 dreams.
I even have the oem mud flaps for the fender flares to go on as well
View attachment 3466831View attachment 3466833View attachment 3466834
Those sure are some clean windowsWent and picked up a cruiser with @Butt Ugly Chuck and had brunch. Thanks again Charlie.
Yep a cruiser in its natural habitat... AT THE PUMP!
Smoked pork nachos.
Jason
TT
View attachment 3472888View attachment 3472889View attachment 3472890
Those sure are some clean windows![]()
Congrats man, if you don't mind posting your results I just want to compare readings from my last report I failed on CO bigtime had to make adjustments.Had to get the 62 Smogged! Hooray it PASSED!
Kinda nervous so ran CRC Guaranteed to Pass Emissions System Cleaner as per instructions (just for some peace of mind, dunno if it really helped or not).
Adjusted ignition timing. Made sure all vacuum lines were connected and no CEL.
Found a SMOG Check Station previously mentioned by fellow Mudder. I live in SGV so tried to find a place 30 min away so I can heat up the cats!
Left it running until time to test.
Pete's Complete Auto Repair in Tujunga, CA (818) 353-2342. Ask for Paul!
Quick and courteous service! Highly recommended!
That popup is sick!!!Added some much needed handles and use 6mm climbing cord to help close the pop-up
View attachment 3473160View attachment 3473161View attachment 3473170
