Yes, but we don't tarp our deer down here in the OzarksWent hunting again with much better luck this time. The carrier works great for one deer but two is a bit sketch. Anyone else take the GX on a hunt?
While you've got it apart, Fab a latch to open the door from the inside.Replaced license plate bulbs and glued rear door speaker foam on. Going to add some sound deadening to the back door when it arrives.
I need to replace one of my skid plate threads also. What length helicoil did you use? Any advice or link to what you purchased would be appreciated.View attachment 3788868
Hit 160k miles. Changed oil, greased drivetrain and suspension, and rotated tires.
While I was down there, I repaired 2 skid plate threads with helicoils. Much easier than I expected, though I probably should have removed the skid plate when I repaired the 2nd one.
View attachment 3788871View attachment 3788872
Loaded up my M3's track wheels for next weekend at Streets of Willow.
This is the kit I used: https://www.amazon.com/dp/B0CF4CJ727?tag=ihco-20I need to replace one of my skid plate threads also. What length helicoil did you use? Any advice or link to what you purchased would be appreciated.
Doe?Went hunting again with much better luck this time. The carrier works great for one deer but two is a bit sketch. Anyone else take the GX on a hunt?View attachment 3788336
Yep 2 does. It's the end of rifle season here in Missouri and it's antlerless only.Doe?
I’m in north east Kansas. Do you have an extended antlerless season that starts in January? We trap after the first of the year.Yep 2 does. It's the end of rifle season here in Missouri and it's antlerless only.
