What Did You Do With Your 120 Today?
10-minute upgrade today. Finally got all the hardware for the back door handle replacement and followed the directions here.
As you can see, next up is doing something about the sad net.
Check out Kaon 4x4 for their steel replacement. It’s very nice...
actually looks alright! Which suspension under there?
5 and 7 yr olds here ;)
Thanks! Mine are 10 & 7. The steps bolt right up with the same holes the OEM steps uses, and I was able to pick up a used set for ~$200. Suspension is OME medium duty kit (886&895 springs IIRC) and their Nitrocharger shocks. I’ve got the Metaltech stage 2 rear coil conversion also. Gave me a pickup of about 2-2.5”. And I also went with the JBA UCA’s and a set of Spidertrax 1.25” spacers
How’s the 886 ride? Do you have the hub to fender measurement? I’m debating between 885 or 886.
They ride GREAT! I went medium duty because I plan on adding a little more weight on the front (HWM & winch), and they ride better than my worn out stock suspension. I'll confirm the springs and pull a measure.
I have bilstein 5100 and ome 885 up front. Jba upper control arms. Stock weight. It’s so ridiculously soft! On big dips on the trail at 15 mph I stuff the 285/70/17’s into the upper inner fender...I would go 886 if I could do it again. But now I’m thinking kings would have been smart from the get go...
We got ourselves out to Trona over the weekend to check out the Pinnacles and give our platform setup a test run...
I ordered the outside door handles and replaced the chrome ones on my 2009. I also removed the rear chrome strip from the rear glass.
I will eventually get rid of the chrome factory roof rack , black out the grill, emblems and rear door chrome.
I'll probably paint the door belt chrome moldings since they are brand new ( replaced by Lexus during the paint recall).
I temporally swapped the wheels and tires from my 3rd gen 4Runner, planning a ski trip to Colorado, my Icon lift and tires will not be here in time.
View attachment 2566274View attachment 2566276View attachment 2566278
Where did you get the door handles?
