Build What did you do to your Land Cruiser/Toyota/Lexus 4X4 this week?
If only there was a way to get one of those elusive limited edition Toyota made screwdrivers....:D
Something like this?
image-jpg.1090169
New apps for the 100 and fuel pump. The apps took a sh*t first then the fuel pump. I praise the Toyota engineers for making an access panel for the fuel pump ☺️
had a great time at the meeting friday night. Was more than a little embarrassed by the duck tape on the CV boot. It was ugly, but kept enough grease in the joint that no damage was done until I could install the new boot. First thing saturday morning. Tore down the drivers side and pullet the axle. Races looked great, hardly a mark on them. Fresh boot installed. No leaks and no more duck tape.
had a great time at the meeting friday night. Was more than a little embarrassed by the duck tape on the CV boot. It was ugly, but kept enough grease in the joint that no damage was done until I could install the new boot. First thing saturday morning. Tore down the drivers side and pullet the axle. Races looked great, hardly a mark on them. Fresh boot installed. No leaks and no more duck tape. View attachment 1125074
When I had an 86 Toyota extra cab pickup and had the boots split I would use a ziplock bag, wrap around the boot and use zip ties to hold bag on so the grease would not leak out. It would worked for a while until I could fix it. Simple things to use to fix problems.
Had CBT install new OEM front control arm bushings, my CSC caster plates and an do an alignment. Night and day difference. Now the back feels like garbage.
Picked up scrap steel plate from Industrial Metal Supply to replace the crap cast iron press plates for my 20 ton HF press getting ready to do my rear control arm and panhard bar bushings.
Swapped out my exhaust hangers
Mounted my Prinsu Designs rack
Extended my axle breathers into the fuel door area and above the master cylinder capped with cheap fuel filters.
Greased my u-joints
Zip tied missing and rotted cable ties under the truck.
Replaced all my lug nuts on one wheel with new OEM
Replaced old OME unit.
Greased my u-joints
No pics?:(:popcorn:
more pics please....looks like you have your work cut out for ya!
Nice project you got a head of you..Looking forward to seeing the build on this one.
