Build What did you do to your Land Cruiser/Toyota/Lexus 4X4 this week?
I moved the driver's side sun visor!
Several times!!
A year later from getting a muffler from @richardlillard1 i finally welded it. And now the Land Cruiser whistle is strong! Lol
Fj40 got new speedo( now its only 10mph off lol) gear new 4wd shift knob as well as new fan duct trailer wire corrected just after a rebuilt F motor cleaned up fuse holders and 3rd eye brake light. so its ready for this weekend... coming up is some rear pinion work next... maybe a 2 inch lift down the road
Added some steps to the Great Pumpkin this weekend.
Lift and bumpers and Super Pacific X1 camp topper on order.
I frequently (at least annually) :) have to add gear oil to the FJ40 transmission. Because it is blocked by the skid plate it is a real pain to get a hose snaked in between the frame and the cab. Every year I swear I'm gonna cut an access hole to fill it from above, but never seem to get around to it.
This year I got around to it because I was going to replace all the oil in the transfer case and transmission and knew I didn't want to fight it pushing a half gallon of oil into the transmission.
I used almost an entire gallon of MT-90 filling up the Orion transfer case and the 3 speed transmission today. Also changed the engine oil & filter.
Marking out the new fill hole
Barely room to fit a 22mm socket through the space between the frame and body
Easy access now
Easy filling now
Welded a few nutz on so won't need to use a wrench
Hole sealed off till next year
Easy access now
Easy filling now
Most would just remove the skid plate and call it good. Personally I just use a floor jack. Little pressure remove the six bolts and lower. I see you have the transmission and transfer case fills connected with a hose. Usually oil migrates to the transmission..if that is the case keeping the transfer full should be set.
On my 65 FJ45 the PO cut the transmission cover in half side to side. Probably done when the transmission was changed from a column to a floor shift. Guess it was easier than removing seat and gas tank. My 65 is 9/64 build date and does not have the optional heater offered in the 65 model. Aftermarket heater heater is above the passenger feet and not a problem removing the transmission cover.
My transfer case is always full - the transmission pumps oil through the seal and into the transfer case, the hose returns some of the oil to the transmission. The rest leaks out of the transfer case rear output shaft onto the ground.
I only ever have to top off the transmission . . .
Finally got some free time this morning to peel away and put another 50 or so miles on this, in hopes to recreate the stalling/no idle issue I ran into a few weeks ago while cruising with the family. No luck, ran great.
I’m sure it’ll happen again the next time I load the girls up to take a drive. Ha.
OME 2.5” lift installed. RCI Off-road sliders added. Front and rear bumpers coming from Expedition One in about 2 weeks.
Super Pacific X1 camp topper coming in about 6-8 weeks.
Created a new hood ornament.
My able bodied pit crew pulled the rear differential, disassembled it, removed the broken pinion, reassembled and reinstalled the now “super” open diff in the sand alongside a trail in Moab.
I got great nephews!
Now I’m driving around 500 miles home in front wheel drive.
Down side of course splines. They do not wear like fine spline but when they fail its a 100% failure. Here is where a full floating axle has an advantage. Drop the driveshaft. Pull the inner axles and bolt on drive plate and rolling again.
You still would be driving on the front axle just less messy being able to do it. My poor 68 been parked in a garage waiting for a clutch. It has Lock Rights in both sides. I couldn't imagine driving 500 miles on the front axle. When I towed it and removed the rear driveshaft. I only locked one hub to drive it in the garage.
