- Thread starter
- #2,441
I gutted the galley in the trailer. Now to make some more panels. Going to add about 8" back into the sleeping area and allow a better layout to be able to work on elec system and upgrade the fridge in the future.
Looking good dudeI gutted the galley in the trailer. Now to make some more panels. Going to add about 8" back into the sleeping area and allow a better layout to be able to work on elec system and upgrade the fridge in the future.
25 deg is a lot, surprised it even ran. Glad you got it going.
This, fuel mileage should improve. You are lugging it nowI'd see where your rpms are with the 4.88s, tire weight probably has effect too
When I am doing 70 MPH ( 65 on the spedo), my RPMs are around 2,500. The 35s (Kenda Klevers RT) are 71 LBS X 5; that's around 355LBS.I'd see where your rpms are with the 4.88s, tire weight probably has effect too
I wouldn't worry about the Kenda's negatively, they are one of the lighter 35x12.50 why I stuck with them and just liking my first set.When I am doing 70 MPH ( 65 on the spedo), my RPMs are around 2,500. The 35s (Kenda Klevers RT) are 71 LBS X 5; that's around 355LBS.
Now I do think that I could look at replacing the fuel pump, injector service kit, and fuel filter, but that all costs money, and I wonder if that is necessary.
yepYou already have the 4.88s installed correct?
I came here to say this. If you want MPGs get a tesla lolUs Land Cruiser owners worry about smiles per mile, not MPG's!![]()
So do you know how many gallons you actually pumped? was it 17 or a guess? Need to take the milage 143 multiply it by 1.08 ( the spedo and mileage appear to be off by about 8%) and divide it by the gallons used. That should give you a more acurate mileage number.Alright, so this last trip to Harrisonburg, I felt like the GX was chugging gas. going from richmond, st. Mary's Falls, then Buchees, was a total of 143 miles, and I ended up with around 1/4 of a tank (6 gallons left out of a 23-gallon tank). Running the numbers, that puts me around 17 gallons used and an MPG of around 9-ish. While I understand the mods affect MPG, I think that a stock getting 15 PMG and now getting 9.5 is a bit excessive. What should I look at to diagnose this?
Also, side note: when I fill up, it doesn't fill to a full tank but splits betwee n3/4 and full.
I'll add more details below
Waiting for a couple more parts, lines, new master, etc to get here. Planning to install the torfab ibooster kit. Hoping this fixes the pedal travel and makes the brakes feel more responsive…Will also fix the trail fix
