pictures to follow.
If anybody has any good tips post up.
I will go to marlins site and print up their instrutions.
pictures to follow.
What exactly are you doing?
Ah, well then, just follow their directions, that's the best advice out there!I tried to outsmart the directions, but didn't win....
to simple.
There is... it's called a tape measure... Put the dual cases together and then measure how far back from the stock hole the new hole is... If you're using the clocked adapter then eyeball how far over it is as well... not hard, I cut my hole out with tin snips. You're just going to put a boot over it anyway...
Hehe You're welcome!oh for christ sake..............to simple.
I really worry about you sometimes. LOL
Good luck with it and don't drop anything on your toe!
I need some real time help.....question about shifters ,plate bla bla
Good luck! How much were the shafts?Good luck! How much were the shafts?
160 bucks to have both shafts done...that's including having the front long travel installed and balanced
