Welding Hood Support- Dangerous?
Seattle
Hi All,
I had to cut the spot welds and remove the center hood support member in order to hammer out some dents in my hood. It looks like a PO forgot to latch the hood at some point, and it flew up and hit the windshield.
The center support was also pretty bent, so I had to hammer it out as well. The center support is glued to the hood from the factory, rather than welded. In my infinite wisdom, I thought to myself, poppycock. It will be much stronger if I tack it down in a few spots.
Then I remembered reading on Gozzard's website (fiberglass FJ40 parts seller) that their hood is really strong and is for off-road use only... I read on the forum that this is because it could become a guillotine in a collision.
So should I have not done this? will my hood not crumple in an accident? If so, I'll cut the spot welds and redo it (annoying but not the end of the world). What adhesive should I use in that case, to match the factory method?
Thanks!
Peter
^^^^ what he said. ^^^^^^
Unless you have added airbags and side curtain airbags to your 40, and made crumple zones in the frame, in which case you should definately redo it.
I won't advise you what to do, but I sure as heck wouldn't worry about it.
The only thing you may notice over time is the welds reflecting onto the top side as dimples or depressions from flexing.
As do all the spot welds on a 40!
I would think that it wasn’t welded so that it could absorb some of the expansion/ contraction / flexing of all the sheet metal. If you weld it down, it might end up cracking or tearing the hood
I always assumed hoods were not welded due to the issue raised above; spot welds would show in the finish. Welded or glued, I don't think matters, either will tear loose if they want. If you have a T100 they just come completely unglued like mine and it bounces and vibrates all day going down the road. I've tried re-gluing it twice and it still pops loose. So I say weld it and go on.
Well, if your head was severed it might ease the pain being caused by the steering column that was driven through your chest.
Drive slow and defensively.
I had to attach my my hood latch to a used bib that did not have the latch after it was painted. The body shop gave me a 3M two part metal weld epoxy adhesive to attach it. I was skeptical. I cleaned everything to bare metal and stuck it on. It has held for 4k miles. The body shop said once they are together, you wont get them apart.
haha, fair enough!
We all know the lack of safety driving old vehicles. I got my license in 1975. No air bags. No crumple zones. I drove a 1965 VW bug. As I remember there was talk of the Vw hood severing heads. VW, Very Worst place to be in an accident.
