welding center diff for part time 4wd
OK guys here it is: Ive done this to several 80s including my own it is one hell of a great mod. Basically its no different than the kit. All you have to do is through away the viscus, do some welding, build a spacer, install hubs and a CDL switch, oh yea do the 7 pin.
Brian
Wow, that's cool! I thought it was a lot more modification to the "center diff" to make it a 'transfer case". Being old school, I like the idea of part time for a rig used off road frequently. I can see the advantage to this for the Longfield guys and those who use their rigs mainly for wheeling. But, my 80 is still relied on for high pavement mileage. Plus the VC and drive train is still in good working order and relatively vibration free. I can see doing this mod later on, though. Thanks for sharing. Maybe you can put a step by step with pics in a FAQ for us! :hhmm:
X3
Is that gold looking thing he calls a spacer homemade or is that part of the VC? The washer thing kind of looks lika a thrust washer in the differntials.
I would love to see a DIY, step-by-step with pics... If anybody is interested. :cheers:
It is a thrust washer from the spiders which are no longer used. It serves to keep the other side gear in place.
And this whole thing was preheated, and TIG welded in about 7 passes. This is not a task for a beginning welder. If it fails you will loose ALL drive and likely destroy the rest of the case while you are at it.
So, NOW do you believe me? Weld up the center diff=rear DS has full time power. Weld up center diff = spool :D
Let me elaborate on why the pin 7 mod is very important now. If you don't do this mod, every time you slap her into Low, you'll have 4x4 (4Low). This is because the CDL will engage automatically when you shift the Tcase into LOW.
If you do the mod, when you go into Low, you'll have ONLY 2Low (CDL will NOT activate automatically). Unless you push the CDL button, your front DS WILL NOT engage.
HTH.
Which is how most modern PT4wd systems work anyway. :D
Ideal solution. Glad I already did the pin 7 mod.
More pics + writeup, please. :beer:
HTH.
Thanks for that. Not sure that i need it but good to know I can if desired..:)
I hate to disagree with you guys but I have two clicking Longfield's with less than 10k miles on them that would disagree with you... It all depends on the situation and how the rig is set up and used. I, for one, could care less about MPG gains but would love to stop wearing out Longs!:cheers:
I totally understand that, like I said I did not know enough about this but felt the need to give my two pennies. I thought they achieved by removing VC and adding a spool and hubs and "peformance gains" (fuel mileage) was not improved. In your case where you have a heavily modified truck and would like to keep parts from wearing out I understand. For me I with a stock rig I think I would have minimal benefits as I could go another 150-160k withought replacing birfs, and at the rate I'm going that will be another 16 or 17 years and will either be my daughters truck( if I can keep her up good enough) or sitting in a junk yard.
I still don't think that you understand what you're saying. In my experience, when a diff (center or axle) has been converted to a "spool" (welded or otherwise), it is locked 100% of the time. You lose the ability to choose. So when this mod is done, only the rear DS becomes full time power. Front DS is still a choice with the old CDL switch. There is no "spool" in this mod. You have converted the center diff to a transfer case because you have eliminated the differentiation between axles. But you still have a choice between 2WD and 4WD. So it's not a spool.
So
......Weld up center diff = spool...
for this mod, is not correct. That's all I'm saying. You could make a spool out of it for a hardcore off road rig. That's generally where spools are run anyway. And in post #6 you said:
With a spool or a center welded diff, the power goes straight to the rear Ds only. When you push the CDL button, power then goes to the front DS.
Cleas as mud? :D
This is what you said that I believe is incorrect. At the time, I didn't know you could mod the center diff like 71-CRUISER is talking about. I thought you had to get a kit. Or if you did weld it, it would be a spool, (100% to both drive shafts), meaning you'd need free wheeling hubs for running on pavement. Maybe we're both more educated, now. I know I am.
i cant wait to try this out and save $600 bucks. im just unclear on a few things and certain parts but im hoping once i have the tc open it should be self explanetory. i figured it could be done i can't wait to do it. like said earlier makes a lot of since on modded rigs and thats what i got and am tired of hauling around all that extra front end garbage from trail to trail. thanks for the great pics and explanations of the process any more pics or instructions are definently welcome.
x2! :cheers:
if i do this mod are all the parts i will need stuff that i will be taking out and replacing in a different configuration or do i need to make sure to have certain parts available before the tear down??
Hubs?
Was wondering if you could just install manual locking hubs on the front axle and let the driveshaft spin freely.
Everything would still be spinning, what's the point?
What would be the bees knees for an 80 series would be a front drive shaft disconnect. Imagine this: locked center diff + disconnected front DS = RWD. Open center diff + connected front DS = stock AWD. Locked center diff + connected front DS = 4WD. Best of all worlds.
