welding center diff for part time 4wd
has anybody welded the center diff of an 80 for the part time conv.
if so was it easy and do you have pics or links and if not do you know of someone who has or where i can look to see how its done. thanks
I believe all you have to do is remove the viciouse coupler. And also add front hubs, although many disapprove of this mod but it can be done. I don't know enough about but from the reports I have not heard any significant gains on this mod. HTH
part time
Very minimal benefits. And welding is permanent. There is a kit available to do the part time conversion as well.
It can and has been done on this board. That dude knew his metallurgy and did a proper job of heating and welding it. Keep searching and you'll find this thread.
With a welded center diff., how do you achieve true rear wheel drive (i.e., no spinning of the front driveshaft)??
With a spool or a center welded diff, the power goes straight to the rear Ds only. When you push the CDL button, power then goes to the front DS.
Cleas as mud? :D
*snip*I don't know enough about but from the reports I have not heard any significant gains on this mod. *snip*
*snip* Very minimal benefits. *snip*
I hate to disagree with you guys but I have two clicking Longfield's with less than 10k miles on them that would disagree with you... It all depends on the situation and how the rig is set up and used. I, for one, could care less about MPG gains but would love to stop wearing out Longs!:cheers:
With a spool or a center welded diff, the power goes straight to the rear Ds only. When you push the CDL button, power then goes to the front DS.....
You're kidding, right?
Center diff welded = both drive shafts have power 100% of the time. CDL switch becomes useless. Free wheeling hubs become necessary. Longfields wear out faster as Chad pointed out.
I guess that depends on what you weld...
OK guys here it is: Ive done this to several 80s including my own it is one hell of a great mod. Basically its no different than the kit. All you have to do is through away the viscus, do some welding, build a spacer, install hubs and a CDL switch, oh yea do the 7 pin.
Brian
Michael--
You were able to do this without pulling the entire xfer case and by just pulling off the rear extension housing correct?
Alsom what is the "spacer" you speak of?
Nice job on this. Very cool.
:clap:
This is Brian not Michael, just using his log on because its up already. The spacer keeps the spider that is left in the case in place.
This mod can easily be done with just the removal of the last two case parts ( the extension housing and the rear most case housing )
This mod can easily be done with just the removal of the last two case parts ( the extension hosing and the rear most case housing )
Copy. Sorry about that Brian.
I assume you don't happen to have a pic. of the spacer as well on the spider gear do you?
I like this DIY approach to this.
I assume you guys also used Aisin hubs and notched the shaft a bit farther out for a new c-clip as well on the birf?
Thanks.
No I have a 94 so I used Warns. ( and they were cheap ) had to shave just a bit off of the hub gears.
Also, What's the 7 pin mod? I didn't find anything in my search
Try "pin 7 mod" - search in titles only, in the 80-series tech. Basically it allows you to shift into low range with out auto-locking the CDL.
Can this mod be done to a 91-92 80 series since they dont have the VC? Can you elaborate on the spacer, what is it for? Forgive me for aking, Im just trying to picture this cause I dont know what these parts look like in the transfercase.
Brian
