I would also check the ground cables at both ends from the battery. Ground problems can cause all sorts of odd symptoms. Make sure the ground cables to the battery are in decent shape and tightly connected at both ends.
If the battery is good, solid, the only power source that is common with Ign and clock is the black/blue circuit out of one of the fusible links to the under hood fuse box. A bad/intermittent connection in that area would take out the Ign switch (50A AM1 fuse) and dome fuse (clock).
Definitely will check that later today, fusible link is oem and only couple of years old but will swap to my original that I kept and see.
I noticed you left my name off that list....The wealth of knowledge that some possess about these trucks is insane. We should be passing a hat to make sure people like @Tools R Us @inkpot @jonheld @beno and others have proper healthcare. We should also lock them in a secure location. They should never been in one location at the same time.
Isn't there another spot behind the glovebox somewhere that the harness tends to get pinched and shorted? I've seen it mentioned in a few threads but I can't find one with good pictures at the moment.
On my 97 LX450 the ECU harness was potentially a problem. I had read about this issue about a month ago and had a close look at that area before I left for my recent trip. There was signs of chafed wires and although it hadn't gotten bad, I addressed the issue anyway.I think the "underneath the glovebox" problem doesn't apply to Lexus. The harness is formed with slightly different angles and doesn't make contact with the metal support bar. Not sure if this is true on all model years, but at least on a '97 Lexus it is not an issue.
You're on a list all by yourself @Aloha Jen!
Free translation: Ignored.
You are not cool enough to play with us. That's what he meant.
There is also another wiring harness that runs vertically behind the ECU that is potentially a problem as well and this is visible once the ECU and the 3 harnesses are moved out of the way. Both are now secure.
Yep. That's the thread I saw.So then I'm not sure when/where the different harness comes into play. I was on a trip about a month ago when someone in our party with a '97 Lexus suddenly started having a misfire/rough-running motor at highway speeds. I looked at the wiring harness in that location and was surprised to find the harness routing was significantly different than my '97 FZJ80. I attributed it to Leuxs vs Toyota, since I know there are indeed some wiring harness differences. But there must be more to it than that. I know only OBD-II trucks are susceptible to this particular problem, but not sure why my friends Lexus was also immune.
EDIT: Here's the original thread that describes the glove box problem area: Another place to inspect engine wire harness
Got plenty of bikini pics, just tell the mods not to banish me!
I thought you could post them as long as it was in your Build Threads and not the more public threads, i.e. "What did you do with your....". Am I wrong?
Well, I think finally found the root cause and it's not what I thought it would be. Yup my 3 year old Die Hard platinum AGM 31m expensive ass battery was the cause! WTF! I didn't try to swap that out because it metered 12-13v the whole time I checked it. So frustrated but happy that it's over. Think there is something wrong internally with that where is would drop voltage to nothing for brief moment.
Will check in the morning on cold start but ever since I went to Costco and installed the el cheapo interstate battery everything couldn't be more normal.
