I started out on a gravel driveway, about twenty years ago, cardboard helps.
I just installed a 2F OEM carb from City Racer. I live at 6,800-feet. I'm happy. The OEM '75 carb would stall immediately after starting, now it it in good shape. Rebuilding a carb might get you 90% there, as it did for me. Now, I'm running a 138 primary jet, instead of the 144 that came with the '75, and I no longer have a lean symptom as bad on a cold motor. Running headers, so it probably isn't that good in the winter. But the new Aisan carb was well worth the money. Only problem is the original choke cable protrudes too far, and I don't want to cut it.
I'm a big fan of Weber on my Nissan. The design of the Aisan is a bit funky in the air horn. The Weber's air horn isn't a crazy pathway for the air to flow with major hardware considerations for mounting the venturis. The Weber's pump jet doesn't spray all over the air horn, and into the early EGR tube, it goes right to the opening at the throttle plate. The electric-choke Weber options offer the only new throttle positioner diaphragm, which is good for people who don't know much about carburetors, and manual chokes (average mechanics, family, fuel-injected folks, etc). My two '75 throttle positioner diaphragms are minor vac leaks with no easy fix. The '75 carbs have minor vacuum leaks on the power valves, again no easy fix. My motor has low vac and compression. Running the non-USA Aisan choke, and the OEM '75 choke, creates a lean symptom at medium throttle when cold. But, I'm just going to install a hand-throttle for the accelerator pedal, and call it good.
I ran a DGEV for an afternoon on my 40. It was super responsive. It lacked on the highway, in a lean way. I was thinking of a 38/38. I bought a 38/38 DGS-manual choke. The choke requires a different set-up than the DGV on my Nissan, so I never got anywhere with it before winter. This spring, I learned that City Racer was offering an affordable non-USA, OEM carb. It comes with two jet options. He also offers the made-in-Japan clone. I'd go with the made-in-Japan if I was a gambling type or low on carb funds.
What is your vacuum at idle?
What is your average compression?
Do you have vacuum advance on the distributor?
Do your plugs stay kinda clean after running it for a while?
Are you sure that your brake booster and all other vacuum components are up to speed?
