Weber 38 carb issue
knuckle47
I can’t get enough Land Cruiser
New Jersey
Funny thing happened today where I started it up fine ..as it has been since I got it 1 month ago. Electric Choke works great as well but after I started out and got to a stop sign, she wouldn’t idle..just die…if I depressed the accelerator pedal to equal the 700 rpm idle speed it was fine. As if the throttle cable was setting the idle speed and it slipped 1/8”. Besides that, no problem. All this happened out of the clear blue sky, as they say.
i don’t believe the idle speed adjustment would slip this much. So I am looking for a Weber 38 manual but have not had any luck…. Does some one know where I might find a manual to check out?
while I’m at it…I am also looking for more details on the HEI distributor made by Davis Unified Ignition. I believe it is a 80820BL…from what I’ve found so far…it matches a Toyota Land Cruiser in the spec sheet online but again, no manual.…which I am also looking for
thanks
in advance
sure it doesnt have a vacuum leak?.....what with the leakmaster 3000 stack of adapter plates.
i would go with a petronix before a dui.
Thanks Brian, in the month I have had it…I have converted many things back to stock or improved the modifications that were performed. Was not planning on dropping a bunch more money into this yet but I may decide to and just enjoy riding it around all summer. You have a good history with FJ’s. Do you have a recommendation on which distributor? I have added an igniter to my t-bird…works good so far
I’ve had this happen on my Weber 38 before. For me it was a clogged idle jet. They are each side of the carb. Remove, blow them out and put back in. Don’t lose the o rings.
I will try these today and Thursday as time permits….I finally got the steering problems finished and properly set up and I was looking to give it a nice test run. Then abracadabra ….no idle
i’m one of those people that rarely reads instruction … but now I’m searching for all of them. For the old timers: our VCR clock flashed for 10 years!
Look at the brass barrel your throttle cable wire is attached to, it does not swivel, sooooo wire wants to bend every time you give the engine throttle (constantly). Now look at the brass cable fitting in ebay #265615452559, it swivels (always) so that you are never "kinking" the wire- - -this should radically improve your throttling, and returning to idle rpm properly.
Thank you @Downey ..bought the cable and swivel barrel, replaced the fuel filter and the rubber fuel lines cleaned out the float bowl and jets. Seems to run well again. I‘m not exactly sure which item resolved this but the jets look clear and certainly flushed out the bowl with some small gunk particles.
@Downey … Jim, do you remember these 1/2 cabs? Bought this top in 1976…
My old one did this once. It was the electric choke not functioning. I converted it to mechanical and it was better. Weber carbs also need like 3psi so I put an inline regulator on it and it ran much better. It was never as reliable as the stock carb. I run a sniper now and it's so much better. The tuning sheet that was posted is very helpful. I think thevredline website has all of the tuning sheets.
what distributor are you using with the Sniper and are you using the timing function in the EFI or just the distributor?
@graham5david Are you happy with that combo? Any surprises bad or good?
I love it. Just fire it up and go. It has been pretty trouble free. The only thing I found was it runs better if I set the AFR a little rich vs the standard 14.5. I don't remember the settings off the top of my head but I set the idle, cruise and WOT richer than the sniper tuning guide called for and it ran better. At the factory settings it would bog on full throttle and die when coming to a stop on occasion. With it set a little rich compared to stock sniper settings runs perfect. It is very easy to adjust.
