Weber 38/38 Carb Problems
Ref: 1971 FJ40
After a trail ride my F engine will not hold an idle. If I let it cool down a little it will maintain an idle and then slowly konk out.
It happened after going through a shallow (10 inch) creek and up the embankment and having to winch myself up. I checked all vacuum hoses and connections; even had to "spice up" the idle set screw to no avail.
Any suggestions are appreciated, fellas.
If it has a float chamber, give it a whack while it's running on a corner of the chamber with the handle of a #1 philips screwdriver.
DON'T use a flat tipped screwdriver!
Didn't work. We noticed to the fuel filter chamber was not but only 1/4 full. Is this normal? Timing, distributor, points, spark gap all were within tollerances. Runs fine but just won't idle long when warm. Idle fluctuates when warm and then dies. Works fine cold. What gives? :confused: Checked the jets and readjusted them to the manual. It just has to be something in the carb but what?
2badfjs said:
a fuel pres regulator?
i think weber says to run about 2 1/2 pounds of pressure
Thing is it ran fine before and then after the wheeling trip this started.
GreenWeeny78 said:
Go Aisin and never worry about that s***ty weber again.
It worked fine before. Did I mention that. And I also have a "s***ty weber" and never had a problem.
Thanks for the comment it helped so much. :flipoff2:
CruisinGA said:
It is giving you a hint. Now is your chance. My 3 spd tranny works. It is still s***ty. :flipoff2:
You don't need to thank me for the help. :grinpimp:
Don't worry. I won't. LOL :flipoff2:
2badfjs said:
did the dizzy get wet by chance?
that'll do it every time
I'm sure it did. He sank it to the front emblem. But it's been over a week. Is there something we overlooked.
So, it runs when it is choked (cold)--you have an automatic choke, right?
And, the fuel in the float bowl is low.
Crap in your carb?
Crap in your carb?
Automatic
I cannot tell if it is low in the float bowl on a weber
I'm thinking crap also. Might be time for a rebuild.
I was also thinking a weak or going bad fuel pump.
The weber needs to be ultra clean. That means no water, dirt , dust or anything. Have you tried to set it back to factory specs. You might need new jets. Try and get over the fact that it ran good before- this will haunt you and keep you from finding out what is really wrong.
Could also need a float adjustment...
http://www.webercarburetors.com/ppw/html/tech/38_dgas_tunning.htm
you should still try
to dry out the dizzy.
moisture will still condensate inside the dizzy.
use brake cleaner to disapate the moisture.
leave the dizzy open for awhile.
brake cleaner will evaporate,no resadue
It could also be your automatic coil in the weber. The spring I had was too strong and it would flood down during cooldowns...
I replaced it with a manual choke, granted I micromanage everything anyway, but at least the manual choke I can check one fault off the list.
Try some more..it's a learned technique that often takes years to master. The float bowl whack will temporarily unstick the sticking float and reveal the problem.
Remember, it's not how hard you whack but where, it's where and how hard when.
Got it?
Good.
Tooth Fairy said:
Does it run okay in any other positions?
IOW, if you could keep it running does it accelerate fine? Anything else?
Yes, it runs fine otherwise. It only stalls when it comes up to normal temperature and I either let it idle for 5 minutes, or when I have to come to a stop sign.
When I take off the air filter and look down the moth of the carb, the fuel drops about three or four drops a second. However, this dripping is often irregular, meaning that it will stop dripping for a 1/2 second or so.
