Water pump replacement, questions
Chino, CA
Newbie here, so take it easy,
I need to replace my water pump (77 FJ40, 2F, stock). Can someone post a pic of where the oil cooler would be? I'm pretty certain I don't have one, but since I'm new at this I wanted to make sure.
I also read on this board that it's probably a good idea to replace the fan clutch. Is that a doable job for a newbie? From the FSM looks like I need some special equipment for pressing the clutch on.
Checked with cruiserdan for an OEM pump, no go. Napa has one with the pulley and fan clutch for a decent price. Or could I user a later year pump that has OEM's available? Or just go with Napa or SOR?
Help is greatly appreciated!
Thanks,
Sean.
Oil cooler, no oil cooler
OK, found a good pic at cool cruisers showing where the oil cooler fitting is. That takes care of that question.
Any help on the others?
Do not mess with the fan clutch unless it is bad. They are not available new anymore and people have had mixed luck with the rebuild kits. I bought a new Toyota water pump about seven years ago for my 79. Does anyone know when Toyota stopped making 2F waterpumps? That seems strange.
There may be later year pumps available (post 1/79). Can you use a later year pump on a 77 (12/76)?
Also, according to the SOR site, they have OEM 8/76 - 1/79 water pumps WITH the oil cooler. Can you use one of these and just cap off the oil cooler fitting?
Sean.
Just got off the phone with CruiserDan looking for exactly the same stuff for a 10/77 stock 40. No luck on OEM so the options are as follows:
-Get a waterpump/fan clutch/pulley from a 60 and try to make it fit.
-Go all aftermarket parts
-Go aftermarket on the waterpump and rebuilt the fan clutch yourself.
I'm going with option 3 to save a little money. I'm also not crazy about capping a fiiting on the waterpump. Check the archives or faq, as I found information including pics on the FC rebuild.
Anyone else have a source for OEM or advice on which option is best?
Pimp, you say a lot in the archives that rebuilding the FC is pointless, can you look on your rigs and see if the FC/waterpump from a 60 series will work? I would guess you would have a different pulley at least.
Thanks!
go with the later pump that has the cooler fitting.
my '77 has a pump, as well as the cooler, off a 6/79.
the cooler stuff is a bolt on replacement for those not "supplied" with one:grinpimp:
i've also been running the last 6months with the fitting on the pump blocked off. i'm just screwing around picking up oem hoses for the cooler.
I'm also having a heckofa time finding a waterpump locally, nobody has one in stock. I have the extra outlet plugged with my (autometer) water temp sender...
I've never had a problem with aftermarket water pumps, but stay away from aftermarket fan clutch. If you have napa or autozone, some of those, most can get it overnight for you.
Sean.
I wanted to fit an oil cooler to my 12/76 motor after I rebuilt it. Bought a pump from Toyota for a '79 I think and it seems to line up just fine. Also used a T-stat housing off a FJ60(4 bolt) with the oil cooler fitting.
I'd say put a cooler on it and use the later OEM pump.
JMO, though
Ed
Brian, the hose that comes off the T-stat housing is available, as is the hose that comes off the waterpump and goes to the cooler, but the one that goes from the rear port on the cooler to the hard pipe on the valve cover is not, but can prettyeasily be replaced with length of plain ol' heater hose.
Ed
Ed
i have the hoses to & from the cooler($$pector and boy did they kill me on S&H), i can't find the upper rad hose for the '79 upper T-stat housing. although i hav'nt hit Cdan yet.
you even gonna put that engine in a truck:flipoff2: :flipoff2:
Hah! How do you know it's not already in the truck? I even have some pictures of me when I had hair!!!
Ed
This is interesting, and I guess the WP availability is hit or miss. Last year I got an OEM water pump for my 8/76 with oil cooler. This pump is fairly unique in that it uses a non-clutched fan, but has an oil cooler output. I believe it is unique to "California" models. It might work in a '77 with an oil cooler if you changed the fan. If you had to cap the oil cooler output, that shouldn't be too hard. CCoT used to well a WP that came with a similar cap.
AFAIK, they're still around Andy. I just shipped on to Oregon on Wednesday.;)
Cool Mark-so you are the source!
What did you ever do with the "left over" H55f?
Replacing clutch fan
As far as replacing the clutch fan, my fan runs all of the time, even from a cold start. So I assume it needs replacing/rebuilding.
Not sure if I'll try an aftermarket fan clutch or a rebuild.
I didn't really want to install an oil cooler. I may end up going with the pump/pulley/clutch combo that CCOT has.
Sean.
