Water pump blow out,need some solid advice..
Salt Lake City, UT
As I was driving on the freeway, I had the AT oil temp light, brake light, and battery light come on. Pulled over and parked in a gas station very quickly, 30 seconds.
Coolant was everywhere and after free tow to a firestone they showed my the coolant is just pouring out of the water pump.
I have had white smoke on startup for a while, goes away in 2 seconds. Anyway they say it failed a head gasket test.
I have the truck back at my house now. Changing the pump is easy and I do have FSM. I don't believe I ever saw the coolant temp gauge any hgher than normal.
My question is what should I do, spend the 135 for a new pump, replace, and start her up? Shop wants 700 for the pump (pfft) but a grand for a head gasket. I'm fine with a grand to keep her going but what if the head is warped? Anything I can do other that fix pump and start her?
Thank you for any help guys. Car has 210k on it but no rust and drives great.
Thanks, and from reading here the pump job seems pretty straightforward.
About the A/T Oil temp light, I didn't know the AT oil cooler used coolant too? I though it was just the AT fluid that pumps through the cooler... but any idea how hot would ruin the tranny? Could a minute of no coolant in the cooler have damaged it?
Explain the failed HG test?
Have you done the Radiator test for Exhaust Gas from Autozone which is free?
Well, I have limited info on the HG test, as the mechanic was gone who did it when I had it towed home.
They told me they did a test, engine running, to test for coolant in exhaust. That's all I know.
As for the autozone test, I haven't done it. Right now, when I fill the radiator up, it POURS out of the pump. It's a good size leak... I believe the pumps bearing exploded? I remember feeling something "let go" right before the warning lights as if the pump was laboring and finally gave out.
None of what you have mentioned explains why there is exhaust gas in Antifreeze.
I would fully investigate that before going any further.
Autozone kit will take longer to go get then to use.
The A/T fluid is cooled in the radiator, so if the radiator got hot, the trans could have also. Just because the light briefly came on, is no indication of trans failure.
I see no way of doing a meaningful test with the cooling system leaking?:confused:
Sounds right, the early pumps are known to catastrophically shell the bearings. Not a common deal, but enough have done it.
Haha if they want $700 to replace a pump but will do the head gasket job for $1000 they obviously have no idea what they are talking about. :)
So, is the AutoZone test something I can do with a bullet hole size coolant leak? Or you are saying I should get a new pump on, then do that test?
Because I feel the same as ToolsrUS, how could they or me test it with a leak that big.
Ya... I didn't want to get into it but they quoted 5 hours for the pump....... no idea why. It's basic enough I'll tackle it myself and just go from there...
You have to buy a new water pump either way. Spend $130 and roll the dice. After you replace the pump then you can figure out what exactly is going on.
My guess is that the dealership is guessing on the HG. A lot of guys have what they describe as "white smoke" on startup of vehicles with 200k on them. Doesn't mean it is coolant getting in to the motor.
Alright so I called firestone, they said they did the exhaust gas test atop the radiator, and it did show there was gas in the coolant while engine was running.... Thoughts? Maybe Its been that way for a while, no way to know.
If you do end up having to have a new head gasket, make sure the person doing the work quotes you a price for removal and checking the head for warpage and then calls you to give you the results so you can decide what to do next before any other work is done.
Alright so I called firestone, ...
Nuff said...
I would put a new pump on it, fill with coolant, drive and see what you have. I wouldn't let Firestone touch it, check air pressure,,, maybe?:hillbilly:
On the early head, cracks are much more common than warp.
Nuff said...
I have geico roadside, a whole2 dollars every6 months, and they towed there for free! But I Will do the pump for sure.
... I have had white smoke on startup for a while, goes away in 2 seconds. ...
Depending on weather, etc, some white smoke/moisture drip, when first cold started, is normal, condensation evaporating out of the exhaust. With some shops, if you ask about, want to buy a head gasket, they will sell you one, it's good ($$$$) business.
So... Thepump exploded, fan Is not spinning and off its axis. Thoughts now? Car starts great, pulled it into driveway to replace pump, but let's say hypothetically you have no Water pump for 2 minutes, is that garauteed damage?
I'm so mad at myself for letting this happen, I had severe vibrating the last week but thought it was I broken engine mount....
The radiator has a small dent, hard to say if it is deep enough to have damaged it, but doesn't look like it did.
I keep 22nd guessing myself as to how long it was running but max 3 minutes, I just so hope your right and there was no damage, it was smoking under the hood 10 seconds before I turned it off, but all the belts were slipping cause of the coolant so I think the belts were smoking... I hope.
I really appreciate all the help here.
Where do I access the fly wheel to tighten the crank pulley nut? I need to do the seal.
