Supremely inexperienced and nervous driver.
I preach and preach and preach...
Don’t try and change your direction while on the obstacle!
Use all that open space before the obstacle to get the truck lined up for a strait on decent (or climb). That way, force will continued to be directed to the front, and not to the sides.
Also, don’t fight the terrain, because it will win every time. The driver kept adding more and more turning angle, which the terrain was quick to reply back with, “na bro, you’re just NOT going to go up that.”
The most traction a 4x4 can provide is when all tires are face strait forward, every degree the front tires are turned, less traction is available. So if you slide with your tires turns a little, you will be garunteed to slide easier with more turning of the wheels. In that situation, your only option is to ride out the line you choose before you got onto the obstacle.
But had he lined up the decent from the get go, started off on the right side of the road, would of gone strait down.
