Warped block!!!!!!
Seattle, WA
According to our mechanic, block is toast after HG failure and superheating. He wants to buy a new Toyota short block (about $4000), machine the head and valves ($900), replace almost everything else attached to the engine and charge about 30 hours labor for a grand total of about $8000. He'd give a 3 year warranty on the engine. It's a '96 with 150K, no lockers, solid otherwise. Help me do the math. I was balking at the cost just for the HG replacement, but convinced myself that I couldn't get a better vehicle for $4000. Now we're talking about twice that, but I feel the same way. I know I'm asking the wrong people, but is this just stupid?
Time to start shopping for another cruiser... another mechanic... or a used motor. You can buy a really clean 96 LC/LX for what you're being quoted for the job.
Tough call - how long would you keep the truck if you thought the 'new' engine would last another 150-200,000 miles or more? Will you get that kind of mileage with any other vehicle you can buy for $4000. Not a question want to have to answer.
Yeah, x2 on the used motor. Or another used '80 and part out the one you've got.
$8,000 is just too much coin to put into getting it back to where it was.
Now $8K for mods, that's a different story! :hillbilly:
Where are you located?
Dan
Wrong people? My advice was to sell the truck as is and not worry about it any more. ;)
What about finding a used engine? Seems price is $1-2k for used engines w/ 100k+ miles. Perhaps another $1k to install it? (honestly, I don't know price to install engine) While you could 'freshen' the used engine, to avoid hemorrhaging cash installing the engine and freshening it as needed may be the quickest & cheapest route.
(edit: I'm slow on the draw, X-whatever on the used engine)
$8K? Hell no. Buy another cruiser and part that one- meaning take the parts you want and sell the rest in bulk. Or find a donor motor, might be a better option. Something has to be better than an $8K engine.
You can get a new short block OEM from Toyota for about $3000 from CDan. Do the work yourself and you would probably come in at less than $5000 and guarantee yourself at least 300K miles from the powerplant at least.
How badly did you overheat the engine? Plenty of people blow the HG without warping the block.
If it IS warped, then get a used engine and pop it in. It shouldn't be nearly that expensive. If you feel up to it, I would do the work yourself, you will learn a lot and save a lot of $$$.
"grand total of about $8000"
NO WAY! For that price you might as well put in a sweet diesel.
Is he putting a straight edge on the deck? I have seen blocks that have some bad pitting but never a warped deck. And is the head warped also?
How do the cylinder walls look?
I would get a second opinion on the warped block. Unless, it does not rotate by hand and is binding.
I agree. It takes a whole helluva lot to warp these big iron chunks.. You may have some warping at the deck surface, but that alone does not make the block a boat anchor.
I would say you've got to have a machinist evaluate the block, not a mechanic. They are two very different people, machinists and mechanics.
And NO F'in way should you spend $8K on that, that's crazy. Should be half that or less.
If you've already got the cruiser torn apart at the mechanics, that does put you at his mercy somewhat and that is not a good place to be.
Refresh my memory, what exactly happened? How hot did you get it and for how long? If the engine "superheated", I'd think there would also be some other issues, like head problems. Cracks, serious warpage, etc. heads tend to mess up way before the block, more heat in the heads, thinner castings, etc. So what he's saying doesn't make a lot of sense to me.
Maybe this guy is looking to fund his kids' college fund here????
I'm with LA Cruiser on all counts. You're at his mercy for the hours of a teardown at this juncture, but I'm doubting the warped block. Perhaps some surface issues that could be cured by today's state of the art engine epoxies in mere minutes, but a warped block? If I were you I'd be posting my location ASAP as there are likely others around (like me) who'd drive over and take a look see and speak to the mechanic in a heartbeat. Agree on the mechanic vs machinist comment wholeheartedly. What I think you have is a mechanic unsure of himself who'd like to spend your money to guarantee the rebuild will go together. You need a true mechanic who can handle this at normal shop rates and still guarantee their work. Without a location it's tough to help.
DougM
In the last couple of years, I have seen several warped blocks, low surface blocks and screwed up blocks.
Most of you guys are just guessing. I know Rick does some work on these and most seem to think they work on them. But you guys are blowing smoke when it come to warped blocks and thinking this can not happen. It does.
Ali posted up his pic's on his block with low spots. I have made comments before on Warped blocks. I was in Minnisota a few weeks ago, rebuilding a engine and installing a Supercharger for a customer. His block was .003 out and screwed up on one whole side for almost 1/2 the length of the block(driver side, Toyota's spec is .002).
I know most of you would not drop that kind of money on a engine, because you do the work your self. But a bunch of people out in the real world(outside of mud) will need to pay almost that kind of money or more at dealerships and other shops.
In some ways look at what people pay to restore the 40 and 60's, pigs, and other cruisers. The 80 is getting close to that age where it is viable to buy for a low price and fix it up.
Rick do you know the mark up of his parts and his costs to run his shop, his insurance, what about his labor rate? Yes I do agree it is a bunch, But not a big pay day. He is warranting it for 3 years.
Frank, diesel conversion would cost a whole bunch more than 8 grand(that will buy the 1/2 cut) then where is the labor comeing from?
I really wish people that comment on Mud would think about what they suggest in real numbers for guys that do not work on there own Junk. Now if the guy can work on his own junk, then your recommendations are food for thought. But then why would he be asking about this and talking about his Mechainic?
96 Beast, Can you do your own work? If not then you are a interesting point. Yes, a used long block is a good choice, if you have some parts replaced( a few threads on this). You will pay for this mechainc's labor to install it and maybe change out the head.
This mechanic is marking his parts up with about a 30% mark up. You did not state what his labor rate is, my guess is if he is charging 8 grand and 5 grand is the big parts, then maybe 7-800 more in parts(valve grind kit, water pump, tune up parts, viscous fan clutch, etc), means his shop rate is close to 85-90/hr.
Not a unreasonalbe rate for a shop these days in a bunch of citys across the USA.
You need to make a choice if the truck is worth it to you. If you buy a different 80, what kind of manintaince will you need to do to make it what you want. What if the new truck has a head ghasket problem down the road?
8 grand is a lot of money for a stock rebuild. Good luck with your choice
Based on this thread: https://forum.ih8mud.com/80-series-tech/356099-fix-junk.html looks like the truck is located in or around College Station, TX near Austin.
Yep, it was but I had no faith in the Toyota dealer where it landed, took the advice of bpassmore and upgraded my AAA to Premiere, waited 5 days and had it towed 180 miles here to San Antonio. Took it to an indy recommended by Alamo City Land Cruiser club.
https://forum.ih8mud.com/tx-alamo-city-land-cruisers/181949-recommendations-service-san-antonio.html
It's sitting in their shop with the head off waiting for me to make a decision.
There's a motor from a LX450 with less than 120k in the classifieds. It's in the part-out section. Swap over your accessories, do a few maintenance bits while it's already out, and drop it back in.
Sure appreciate the input. I COULD do the work- but I already have a full life, I don't have all the tools I'd need, I don't have the experience to tell when something's not right, and my biggest helper is in college at A&M. That last fact also diminishes one of the major attractions of the fix, the 3 year warranty. If it goes bad in College Station, it does no good to have the mechanic here.
You're right on- the mechanic's charging $80/hr.
I think I'm gonna put it in the garage, look for a nearby used engine, and fix it when the total cost will be in the 4 grand range. If that doesn't look doable we'll part it out.
Meanwhile I owe the shop 5 hours labor for tearing it apart!
Yeah- from what I understand 10-12 hours to install a new engine. But I'd probably replace the head gasket and do most of those things (hoses, o-rings, gaskets, timing chain, etc) that people do when they replace the HG.
