Voltmeter
Albany, NY
Hi,
I recently run 12V power to the back of the truck. It is connected to my second battery.
It will be easy for me to locate a voltmeter gage, connecting it to the fuse box. However, this will be on all the time since the second battery connection is not switched with the ingnition.
Is the 12V gage a good idea? will it draw too much power with the truck is off? I suppose I can install it with a switch. but that will add complication
Doesn't get much easier than a momentary push button switch in-line with the +12v leg of the meter. Why do you want a volt meter anyway?
-B-
I have a 12v meter also on my second battery. But, it's not like the Autometer types you would expect. It's a little digital LCD meter that pulls about 3mA. The company is Martel Meters, and the meter I bought was the QM100-V with the diode. It fit perfect on my 4Runner dash.
The second battery runs my fridge and I like being able to monitor the voltage after the truck sits for a day or so.
For those who don't already know, A Big common mistake auto electricians make over here in Australia is that the wire they use to run to the back of the truck is too small.
This causes voltage drops and fidges can sut out well before the battery is low on voltage... so make sur you run real nice thick cable and you will have a more efficient fridge :)
Frank
