VIN fraud?
I recently called for an insurance quote and I was told my 95 lancruiser was salvaged and they could not insure (esurance). I was so confused because my truck has been in minor fender bender but never totaled.
I called NJ dvm and they in fact tell me NY reported it crushed in 1997 but I have own the truck since 99. Can any one give me advice, or has anyone experienced something similar? I don't know if anyone can help me with a carfax this is my vin JT3DJ81W4S0095945. Is that detail even in a Car fax? I don't want to spend the 39 dollars only to find out what I already know.
Carfax does show a salvgaed title on 2/23/96 for that VIN.
To start, check the driver door, top left part of the dash and the frame (forget what side) and confirm the VIN is the same. The one on the frame will only be the last 6-8 digits IIRC, not the entire VIN. Then check your title. Are they the same on all 4 places? Does SALVAGE appear on your title anywhere?
I verified the vin on engine on the dash and all 5 doors and it matches I'm digging up my tittle from 1999 now but I'm almost certain it was clean and clear tittle. Is there any way you can send a copy of the car fax report or image I'd really appreciate it, it would help me state my case when I contact dmv. Thanks
What about the frame? No, I won't send the report, sorry. Besides, that won't matter, DMVs don't use Carfax reports, they supply data to Carfax. If you bought it in 1999, it should have showed salvage, it only takes a few months for that to show
Where on the frame is the vin number located?
front passenger side
Well tittle is clear, Everything matches says FZJ 80 and the last 7 digits of vin
My title doesn't say anything and my 80 was totaled. Depends on the state whether the title shows any difference. Just call a different insurance company, 20 years in the past it's water under the bridge unless you want comprehensive coverage (value will be less). Rather than shelling out for the comprehensive, just save some money in a fund and drive more carefully and/or buy bigger bumpers.
How did you insure it the previous 15 years
He said quote, presuming from different insurer. Some care, some don't. Current one could have made him pay regular price all this time and would have just screwed him when he wrecked it.
I ran into this with a motorcycle. Purchased with a clean title, but when i went to register it at the DMV they would not transfer the title because it managed to get a salvage between the years. And long story short in Oregon they just gave me 2 pieces of paperwork, one for a VIN inspection (onsite) and the other statement of how it was repaired in order to get the title transferred. With that said I have not done it yet, but have the paper work ready.
Does this apply to earlier model years like 94?
I haven't looked recently, but as i recall...its on the frame rail just behind the passenger side tire.
Yeah it was just for a quote I currently have insurance. But there is. A mistake somewhere. All the vin numbers match and I have a clean tittle. The vin on the frame is scribed in and is hard to see I had to clean some surface rust to see it right below the y pipe on exhaust.
As I said, I have a clear title. In my hand. From AFTER my LC was totaled. I even registered it AFTER it was declared a total loss and still have a clean title. How? I just registered it in another state with the clean TX title I got when I purchased it.
What I'm trying to say is, if I didn't tell anyone it was totaled when I sell it (in any state other than Texas, probably... or even then since my current one is clean), they would never know... unless their insurance cared, like in your case.
As you can see:
VINCheckSM Total Loss Record
Further information is available through .
VIN: XXXXXXXXX has been identified as a vehicle listed in the VINCheckSM Salvage Records.
Date of loss: 2015-11-03
Cause of loss: Property Damage
Cause of loss: Collision
You are advised to consult with a certified automotive technician before further considering this vehicle, to include verifying the airbag remains intact.
VINCheckSM is updated regularly as additional information is reported.
For what it's worth, yours doesn't show up on VinCheck. VinCheck
Guess Carfax is more reliable (or wrong). Either way, that was in 96, how are you going to find out if it's an error or not?
Yes. My 92 and 94 both have it. Look in through the passenger side wheel well. You'll see FJ XXXXXX or FZJ XXXXXX
Yeah.. mine has FZJXXX chassis number but that's not the VIN.
I had to get a police inspection done when I combined my 94 frame/engine and 97 body.. per the info the police officer had about our rigs there is no actual VIN on the frame. The only way he had to verify that my frame/engine was from the VIN and title I stated was to cross reference the ID number stamped on the engine block.
This is assuming his info is correct.. I haven't scoured every inch of the frame looking for a JT3DXX "VIN" but this experienced police officer trusted his info enough not to bother looking.
FWIW the engine number is pretty hard to see too.. we had luck with carb cleaner on a warm engine block.. as it evaporated off (quickly) we were able to make out enough to confirm his records.
i've run into this and had detailed conversations with my insurance agent. had a dodge get hail damage bad enough to total it in the insurance companies eyes. there threshold is different from the government standard and based on different criteria.
i had the buy back option title never moved from my possession. the truck still had value but the insurance company said i could only carry liability. they stated i could switch companies and get full coverage but in the event of an accident they would assess the value and probably de-rate based on the hail damage. if someone carrying the same insurance hit me i was s*** out of luck they already paid out.
my guess is your truck fallows a similar situation. no it's not insurance fraud unless you try and get paid out for the same damage. they would ask about pre-existing damage to an accident
