- Joined
- Dec 15, 2014
- Threads
- 19
- Messages
- 239
So I was having an intermittent Miss primarily in cylinder #4 but with Misses also showing up in cylinder #2 and 6 as well. It was very short bursts of misses that you didn't even notice unless you were accelerating.
I put my Snap-on Solus scanner on it to collect data as I drove and found out about the misses and what cylinders we're being affected.
Well like a dummy I swapped out the cap and rotor with a used distributor cap and rotor I had laying around.
At the same time I noticed that BOTH BATTERY TERMINALS we're so loose you could not only move them side to side but up and down also!
I tightened both terminals down and then went for a test drive.
There were now no misses!!! Problem solved.
I would have given anything if I had done just one of the repairs and went driving so that I knew what actually fixed my problem.
I would sure love to have your opinion as to BEST GUESS if it was the loose battery terminals causing the problem or the distributor cap rotor swap out that fixed the problem.
I hope that there will be a few of you out there that will take this as a serious question. Can't wait to hear your thoughts.
