valve stem seals. yes/no?
Northern Territory Outback Australia
My truck has 260,000kms on the clock now. It blows a bit of white smoke after idling which seems to be getting worse. Always used oil over the past 5 years I've had it (still burns about same amount as it did then) Is this something I should really worry about or keep on truckin'?
I'm getting really sick of this truck. Just after I typed this I went to go for a drive and low n behold the 2 month old OEX alt dies.. I know it's only running gear but I'm feeling sick if spending a day fixing this thing every few weeks.
they are only new once ;)
if you want something that doesnt have issues be ready to drop the cash for something newer but for my uses an old 80 does just fine.
Looks like you can run with the valve stem issue, but your gonna have to fix the alternator.
I would go Denso Reman if this is not a DD. Denso is the OEM Supplier..... for mine anyhow
Reman
Illustration Details:
  1. Bearing 100% tested to OEM specifications and repacked with OEM grade lubricant.
  2. Stator Insulation tested to 600 volts.
  3. Rotor Performance and insulation tested to 600 volts.
  4. Housing Re-tapped to OEM specifications and damage-checked for heat warping, corrosion, or improper surface alignment.
  5. Hardware 100% stripped and replated.
  6. Rectifier Performance tested to 300 volts.
  7. Voltage Regulator 100% voltage tested to OEM specification.
  8. Slip Ring re-machined to an average of 8 microns (20 micron run-out maximum).
Features:
  • Premium cores and precise OE assembly benchmarks
  • Design to meet the grueling heat and electrical requirements First Time
  • Fit® provides perfect mounting with no belt/pulley alignment issues
Benefits:
  • Service professionals preferred DENSO's alternators for a trouble free solution
  • OE-quality fit, appearance, and durability
  • Full compatibility with sensitive electronics systems
  • Compact and lightweight design
Newsletter Article with Electrical Troubleshooting Tips
Your truck is 18 years old. Think about that for a minute.
You used a non-OEM alternator. That topic has been beaten to death on this forum.
What a pain.
If photoman still has some pulleys, and is willing to ship to oz, maybe get the bigger 130 or 150a alternator out of a newer 'yota and install that.
