valve cover gasket
Seattle, Washington
2 questions:
1. browsing local auto parts stores online, I'm looking for a new valve cover gasket as my engine leaks about a (1) quart every 250 to 350 miles. its getting so bad i can on occasion smell burning oil.
so whats the difference between gasket sets that have the main gasket for the valve cover, "spark plug tube seals" and the sets that have the main V.C. gasket, S.P. seals and something called grommets (these are quite a bit smaller than the spark plug tube seal and number somewhere around 14 or 16)? whats are the grommets for (small rubber grommets)? bolts that bolt down the valve cover?
2. to take the valve cover off, to i need to remove the upper intake or the throttle body off to be able to access valve cover bolts and remove the valve cover its self?
thank you in advance!
you will need to take off the throttle body to do it. the grommets are for the hoses that go to the valve cover. some come with the cam half moons also.
I found that just tightening the bolts for the valve cover solved the problem for me IIRC i couldn't find a torque spec in the FSM so i just went snug but apparently it wasn't tight enough
I want to know too what the small grommets are for?
Its $20 more for the kit with grommets. $20 for two o-rings for the two ports on the valve cover seems a little high to me to be just two o-rings.
Be careful with those bolts on the VC, they are prone to over tightening and snapping. If you look carefully you will see that there are ser=veral tabs on the VC that actually ground out on the head, tightening past that point can shear those weak little bolts. they are very low torque
cheers
The gasket loses it elasticity over time. Tighten works for a short time then it leaks again.
Imagine how many thermal cycles Gskt has been thru.
Get the Spark Plug seals when you do this job.
Only reseal the half moons if they are leaking. They don't move so your likely alright.
I would order a Toyota Gasket along with 6 Toyota Spark plug seals and a new PCV Gasket as well.
You can get PCV Gskt on Ebay. They tend to be brittle so remove when valve cover is off.
You have the Lisle Seal Puller ($10) to remove the spark plug seals? Works like a charm.
Do you know your plug and wire age? If not replace
Plugs are cheap. Wires can be tested for resistance (Buy NGK or Denso if you go aftrmrkt).
Do a New PCV Valve while you have valve cover off unless you know age. Get OEM as the aftermarket one I bought leaked and went in trash.
I recommend a flex head 1/4" Socket to remove back Valve cover bolts. (don't break nipple off radiator when your in there) I did.
Get a few cans of brake cleaner and some Nitrile Gloves as you already said you have oil leak.
There is only one valve cover gasket, 6 spark plug tube seals and a PCV grommet (not a gasket).
There are no little seals/orings like the ones pictured above (what is this crap these companies are pedaling?).
You do need the throttle body gasket to remove the valve cover itself.
You DO NOT need half moons.
X 1000 on all the above. Especially the "replace the PCV" while you are in there.
And replace the plugs and wires with high quality Denso or OEM while you're at it. The more you remove the TB, the better chance you have of breaking something, like the radiator nipple or the intake hose.
I am doing this job this weekend as well, all Toyota parts. The installer could be a moron, but the parts will be great.
2nd on the PCV valve - but read a post where in a mudder took a butane torch to the PCV to "soften" it up and then pulled it out whole with a needle nose - indeed you do not want to have that bugger shred to bits into the valves...
iirc - had to remove the air intake hose, loosen (but not totally remove) TB, and loosen / unbolt the HCV / FHH (at the back of the engine)
in order to access all the valve cover bolts - the back (firewall bolts) being the hardest to access - splayed out over the you engine...
otherwise twas a :banana::banana: job.... no special tools....
bF
Working at the back of the engine bay is a PITA. If you haven't already replaced your heater control valve (at the back of the engine bay, above the VC), now would be a convenient time to do so. With that and the attached hoses out of the way your work at the rear of the VC will be much easier. Also, some gasket tack on the VC gasket will help a lot to keep that VC gasket from wiggling around on you when you turn the VC over to install it. It's a big rubber gasket and it will want to fall out of place. The gasket tack (I used Perma-Tex, which comes in a metal jar with the brush integrated into the lid) is a real frustration and gasket saver.
Good luck.
Those are used on other valve cvrs for say the 100series or the 3.4v6
Did mine a few weeks ago, take the throttle body off completely and clean the hell out of it, After that plenty of room.
Get the distributor of ring and replace it too, takes 5min. Took me longer to degrease all the parts.
I wire brushed my cover for over an hour, look like I had sand blasted when I finished.
It's been about 2 weeks and my engine is oil free, gotta hit the oil pan next and tranny.
Went To Local Part store, THey don't carry throttle Body to intake mount gaskets. Any idea where I get one?
They are metal, so if you don't dork it up, can be reused. It's a good time to replace the throttle body heat, coolant hoses.
We reuse them unless they are damaged. Metal gasket only has to hold a few inches of vacuum, or less than 10 psi if your S/C or turboed.
