valve compressor tool attachment
San Diego, California
Hello,
Was doing the valves on my 1fzfe and the compressor tool couldn't reach down to compress it...
So I made an attachment to make things easy (Would probably work with similarly sized recessed valves in other engines)
Will post pics of it in use tomorrow.
If you have an onshape account:
Onshape
-or-
Thingiverse
1fzfe valve keeper remover by Woofythewolf
I did put it on the spring tester and it took 100 lbs with no flexing/creaking when printed with PLA @220*C .2 mm layer thickness and 2mm between infill lines (probably 20% infill if your slicer does it that way).
And..
I recommend printing in this orientation with support set to everywhere >50* angle from horizontal
