Yes, check those two power steering vacuum lines out, and check the vacuum valve also to make sure one of the little plastic connectors didn't break. I've also heard of those vacuum switches on the back of the power steering pump slitting in half at the diaphragm.
Besides that, check for leaks in the intake pipe downstream of the mass airflow sensor. I've developed leaks on other vehicles there. Sometimes you get a split on the bottom side of the pipe and you can't even see.
Pull the pipe after the maf and check for leaks/crack. Your problem sounds like this could be a possibility. it’s hard to see, you’ll have to pull the part out and inspectWould a leak after the maf cause a lean code normally? I don’t believe my scangauge can pull fuel trim data which may help diagnose that? Really wish the truck would at least idle long enough to smoke test it![]()
Glad you were able to resolve it!
Well headed out for date night and I had a noticeable loss of power, oil pressure tanked and a new chatter from the engine. Chatter got louder so I pulled over.
Video:
The next day I went out, changed to oil to find this:
No change. I’m thinking is valve clatter. Wondering if maybe the oil pump failed causing the clatter? Has anyone had an oil pump fail? Other possible causes or are the stars alighting and it’s literally one break after another?
Valve clatter? You mean rod knock as a result of toasted bearings?
I'll keep my fingers crossed but outlook not so good.Yeah that could be it. Trying to be positive![]()
Hot Oil leaking out of tube seals in the valve cover and into the tubes.Any reason, aside from the plugs backing out, that CP 5 and 6 would be burnt?
I could see that explaining cylinder 4, but wouldn't the cylinder 5 CP markings/burns indicate the heat was more originating at the spark plug?Hot Oil leaking out of tube seals in the valve cover and into the tubes.
Plugs are known for backing out on these rigs and will likely cause the burning on the cp as a result. I'm guessing the ones with the worst burns were the looser(?) plugs.I could see that explaining cylinder 4, but wouldn't the cylinder 5 CP markings/burns indicate the heat was more originating at the spark plug?
Hate to be a Negative Nancy but none of that explains the bottom-endy sound. I'd diagnose the oil pressure issue before tossing more parts at it. I fear oil starvation caused some not insignificant friction-related issues, hopefully not bending metal parts.
