Vacuum Schematic....for TBI
Northern Colorado
I'm doing a TBI swap this weekend and wondering about the vacuum schematic. Anyone have any idea where I can look for one? I'm putting on TBI from a 90 Caprice cop car.
I know a few of the spots to connect to: The MAP sensor hooks up to the one on the back, PCV goes on the big one.
I need brake booster, Vacuum 4wd and EGR.
I see left/right manifold vacuum, and ported vacuum...what do I hook up and where?
My Brake Booster comes off of the Manifold, are you using a TBI mainifold or an adaptor plate?
Map sensor off the rear one,
the rest of mine are Plugged up, "ported Vacuum" used to go to EGR, but i dont have that hooked up anymore!
Great info thanks! I'm using the TBI manifold. I'm using the EGR, so thats good to know thats where it goes. So I can use the right or left to power my 4WD I assume. Power brakes, I suppose I can use one of the "plugged" ports up top for my brakes.
I took a pic of mine then forgot to bring the camera to work, so a description is all you get. Should work though.
For my '93, looking at the front in your picture:
"Left Manifold Vacuum" goes to a T. One branch runs to the EGR control valve, the other branch runs to the air control valve for the smog pump.
"PCV hose connection" - yup
"Right Manifold Vacuum" used to run into the cab to a vacuum gauge, but I plugged it when I was searching for vacuum leaks.
"Ported Vacuum" runs to the fuel evaporation canister.
For brake booster, I have a forward facing port on the intake manifold, just below the throttle body on the right side when looking into the engine bay. Any large diameter vacuum port should work.
HTH. :)
HTH. :)
Awesome...thanks! I'm not running the smog, so thats one less. Maybe I should get a vacuum gauge...then at least I'll have something exciting to look at rather than the RPM gauge. :D
thanks!
