Vacuum Leak or ?
Montana
Ok, So fist of all, I have been searching and I'm slowing getting more confused. I'm mechanically inclined, but do not know much about vacuum. Here is what I have.
1982 FJ45 (Australian), with the 2F engine. It appears to have the original Australian smog stuff.
The problem I have is that when the engine has been running on the hot side (not engine temperature hot, but more like exhaust hot, like after a long climb or pushing it for a while) it does not want to properly idle, the idle speed drops to the point where the engine will stall. If I pump the gas right before it stalls, I can prevent it from dying (this tells me the bowl in the carb has gas), but need to keep it revved up pretty good for it to not die.
Saturday I did a vacuum test, I have the engine idle set high, to prevent it from stalling too easily. Once it has warmed up (still at high idle), I get 14" vacuum at 5,000 ft. Took it for a drive, got it pretty hot, and the idle dropped to what it should probably be, and I get 9" vacuum at 5,000 ft. I believe I have a vacuum leak, I sprayed all the hoses, carb, intake manifold with brake cleaner and starter fluid and did not detect any change in engine speed. I also went ahead and replaced all the vacuum hoses with not luck.
So in summary for the engine idle.
Started up, warm a bit, choke all the way off = high idle.
Drive for a bit in town, engine a bit warmer = regular idle.
Drive on the highway or up a hill, engine exhaust temps higher = very low idle / stall.
It has been doing this since I bought it a few years ago.
Engine water temperature fall all these is typically at normal temp on the original gauge.
Any help or advise is appreciated.
Thanks
Guy
Valves last adjusted when?
That is a good question. No idea. Would valves make a difference in the idle, depending on how hard you have been pushing the engine?
Will need to look at that, could take me a bit to get to that, as the Troopy does not fit in the garage (too tall) and it is winter here.
Also, any thoughts on the vacuum?
Thanks
Valve adjustment is THE baseline.
What's it timed at? Advancing the timing might bring up the vacuum, might help with the low idle too. After you adjust the valves, of course.
Where did you get your vacuum source to get 9" of vacuum? Even at 5k feet you should still get close to 18"HG.
Here you go.Effects of Atmospheric Pressure on Vacuum Level
Thanks. The measurement I got is directly from a port on the intake manifold. I also believe that 9" is low, that is why I thought I might have a leak, but cannot find anything when spraying starter fluid around where a leak could be. As soon as I have a little time with not supper cold weather, I will look at the valves and then report back and go from there.
Thank very much for your advise. I got lucky and Sunday was sunny and in the low thirties, so I managed to adjust the valves (all of them where too close and had to open them). All the problems went away. Vacuum is good at 17" (at 5,000 ft) and no more low idle or stalling. So that I can learn, is this due to the engine now breathing better through the properly opening valves, so it get more vacuum?
Again, thank you. Guy
If intakes do not fully close, they push air back into the intake, which shows as a lower vacuum reading. Past a certain point it will actually push back through the carb itself, as @powthief19 discovered last week.
There is more discussion of vacuum on my FAQ.
Also, remember that the valves cool when closed and if the valves are not fully closing, they aren't properly cooling and more potential to burn valves. So always important to keep a check on valve adjustment.
A permanently installed vacuum guage will help with that
Followed Mark’s Off Road’s suggestion and mouted a pod.
JohnnyC’s solution
Yeah, it’s nice have a scientific device:hillbilly: I don’t particularly care for the plastic capillary tubing included with the autometer kit. I’m going to build a line using AN -2 or AN -3 parts.
I remember the mid-sixties Chevies had a manifold vacuum gauge. Instead of reading Hg it would indicate fuel mileage. Floor it and it showed bad gas mileage:).
Correct, for some reason, most manufacturers never made Vacuum as important. Perhaps a hidden reason. A vacuum gauge is as important as a fuel level gauge. A lot of high end cars have a vacuum gauge misrepresented as a "fuel saver gauge". Indirectly , this is true, but, there is a loss of knowledge as to ill effects of vacuum issues. Many a person has fallen victim to the lack of knowledge of , vacuum.
( Looks like JohnnyC has it figured out )
And I was chasing a suddenly won't idle situation over the past two days. Points were fine, cleaned some soot off of the plugs, would only run with the idle screw all the way in. Went to pick up some new plugs as I couldn't find any vacuum leaks and decided to buzz by my engine mechanic to see if the shop was open on Saturday. It was and it took them just a few minutes to validate the points, plugs and solenoid were all good. Off came the top of the carburetor, pulled the idle screw and there was a piece of crud in the needle. Blew it out, reassembled and adjust idle. Took about thirty minutes, $10.
