Can you weld? I cut my airbox ring and welded another piece of tube that was stepped up to match the MAF size then welded some threaded inserts to the outside of the tube and shaped them with a dremel so they would look like OEM Flanges. The MAF mounts directly to the lid of my Fzj80 airbox lid. The steel tubing between my airbox and MAF is exhaust tubing stretched at an exhaust shop to the right size on one end. IMO the less silicone joints and unions you can have the better
For yours you could do something similar and make a flat plate with a hole cut in the center of it to match the opening of the MAF and your airbox lid. Weld this plate around the circumfrence of the round opening on the end of your airbox lid. Then drill holes that are in the same locations as the holes as your MAF run the stock 4 black bolts on the maf through the plate and into the MAF to bolt it on. Just make sure the splitter vane in the MAF matches up to the splitter vane in your airbox lid. They should both be horizontal
This will allow you to bolt your MAF directly to the lid of the airbox and not use a silicone adapter. For the Throttle body side you have a few options you could do. That big box is just a silencer for noise, you can ditch it and plug the hole and point the stock 90* plastic thing at the fj80 airbox lid (it rotates too) and then run a straight peice of aluminum pipe.
Or you can use a silicone adapter directly on your TB, then run a tight radius 90* bend aluminum tube and run it to the MAF/airbox.
Something like this. Youd cut the short end right before it bends on the flat and it will probably fit under your hood with it closed, youd need to take some measurements. your TB is probably close to 3 inches if id guess
Vibrant Performance offers a complete range of lightweight, top quality 6061 Aluminum Tubing available in a wide array of sizes ranging from 3/4” to 5" (19mm to 127mm) O.D. Our Aluminum Tubing comes in a variety of bend configurations (30 to 180 degrees) and are suitable for use in both...
vibrantperformance.com
They also sell very short radius cast aluminuim elbows as well.
Vibrant Performance Tight Radius Cast Aluminum Elbows are manufactured from 6061 Aluminum and requires minimal surface preparation for tig welding. They are available in outlet diameters ranging from 2” to 3”.
You can also use short radius 15* Pie cuts if you can tig weld.
The main thing you need to do is make sure you can get the tilt of the airbox you have right to set it up flat some. Ive got a steel spacer under the bottom mount to flatten it out some because it likes to tilt down some. My lower airbox is from a fj62 and the lid is from a FZJ80. The fj62 lower air box bolts into existing holes on your truck. I dont think the fj80 one does.
