Kirk, THAT sounds like a LC swap motor. Isn't that gonna be going in the '08 Rangers and Exploders?
It'd be cool. Mega expensive. You won't be able to get fuel in 5 states and good luck finding anyone to fix it if it goes wrong. I doubt you'll be able to find a VW shop that has a tech that can. How long did they import the thing? Less than two years I think and then only sold 450 of them. Tough to get parts or expertise if there's a problem. I just looked in my Alldata to check on prices for parts. No listings for most any parts. That's not a good sign. Good technical pages. If you decide to, feel free to PM me and I'll send em to you.
It'd be like putting an Enzo motor in there. It's possible, but practical?
The big problem is going to be with the computers. Your going to have to find a different way of powering the engine. Because one module fault will cause all kinds of problems and put the engine in limp home mode.
Do a search for Vagcom. It's the main programing software it may have the abilitty to disable some of the input into the ECU. If so then you might be able to make it work.
Having owned two Turdeggs and modified some of the systems on them. I would never even think of moving that engine into another vehicle.
I remember back in the mid-90s when the naysayers were making the same kind of statements about the Vortec engines -- too compicated, too many electrical components, too much chance of component failure. Sure the engine is complicated, but along with that is associated some pretty fabulous German engineering. Properly set up, that engine should be extremely reliable. Go for it Gary!!!!
I have VAG.com... I wouldn't own the t-reg w/o it. There are hacked versions floating around for cheap.
The Corrado has been sitting for some time. It's in excellent shape... it will come out to play again... some day.
It's funny how many VW/AUdi folks are Toyota guys, too. Run with this V10 conversion... just plain cool.
Thats great Greg, with that, all I would need to do is put the tranny in gear, any gear, and both drives shafts would fall of. That thing has to make 750hp at least.
That motor is pretty cool, but it don't look like the torque matches the HP (usually 2:1?). I ain't no expert by no means, just a passin observation...
