V-link Front Suspension
BOTTOM LINE. you can take anything as far as you want to take it, there are different set ups for different ppl's uses. A 4-6" lift and some 35's are perefect for 90% of 80 owners. I am taking mine a little further, but if you want a FULL BLOWN ROCK TRUCK/BUGGY an 80 is the wrong truck.
I find it hard to believe that all the people out there with bronco's and land rovers, and 80's in Austrailia are ALL wrong in their attempt to unbind the front suspension a little.
I agree, and especially with the "little" part :D
In my "Quest for Flex" (thats trademarked by the way :) ) I found out A LOT without actually going to a true 3 link up front etc.
The most change I noticed was the "poor mans 3 link" that in combination with longer shocks allowed the front to balance the rear (before I put the 14" shocks on) and it stayed relatively level. I think this was by far the most balanced of the setup. worked great on the trail and allowed me still really good highway manners.
When the quest continued, I changed to 14" shocks in the rear which then caused the body to lean more now that the rear far outflexxed the front again. At that point it basically just "felt" more tippy and sure I could flex more, but at what expense?
I like the idea of beefing up the front for the poor man's 3-link....or trying to figure out a beefier way to do that. That balances the flex and allows "normal" manners until you want more flex.
In this pic, an 80 did the same line in front of me. They had the OME/L shock standard setup and lifted a tire going over it. I pulled the hitch pin and didn't lift a tire at all. I wasn't even maxing out yet on the front end.
Did it stop either of us from making that climb? No...but I do like the extra couple of inches of flex when I might need it.
attachment.php
I feel that it performed better in the above pic, than when I was going for a lot of flex. here I had quite a bit more flex from the rear. The front flexed and maxxed out my shocks as well, but it was just too much IMO for what I was going to do with the rig.
attachment.php
I sorta figure the X-link type suspension is just that, a beefier poor man's 3 link.
The one interesting thing in the video Slee linked is there really isn't a whole lot of articulation going on on that truck! DS is maybe 6-8" up from the bottom of the flare (depending on where in the bouncing you look) and the PS is at the bottom of the flare. What I see in that video is a truck that is top heavy from the amount of lift it has laying over on it's side, and rearing up on it's hind legs. Obviously the taller you go the more it's going to want to tip back as you climb, it's simply the CG working it's magic.
I also think there is a fundimental difference between sitting at 4" over stock and trying to get more droop on a suspension that you can easily compress to the bumpstops, and trying to get a truck that is 6" over stock to hit bumpstop on one side, and still droop on the other. You have 2" more to compress, multiply that times the spring rate, and that's quite a bit of force. Droop doesn't take much force.
Don't get me wrong, I think it can be improved and you could probably gain some. However everytime this comes up, people start posting pics of trucks on the ramp. The more flexed up they are, the better people think the suspension is. I just wanted to show that there are more to the picture than just ramp pictures.
Yep, we agree, there is more to it than just ramp pictures - but those two pics were easy to grab, and ramps do have the nice part of there not being as many different lines to take as opposed to rocks. If I get motivated, maybe I'll take some shots of my truck climbing a ledge, then pull one of the bolts, ala poor man's, and try to run up the exact same line. Try to get some apples to apples like FJBen did on the ramp - but a little more real world. I'm looking as much at how the body is sitting in those pictures as how the axle is sitting. Which is somewhat the same thing, and somewhat not. I guess on that 3link ramped picture, if the body was in the same possition relative to the axle as the picture of the short bus, it'd be on it's side. In that case I'd rather have it balanced such that you'd start lifting the front tire before you roll.
I think your design is good out of the box thinking. I can see the benefits you mentioned in setting everything up and then just cutting the front part of the control arm off. I am just not sure you are going to get that link positioned under the truck. .
I'm not sure I can get that link possitioned under the truck either. I do get a little more room having the drop brackets, the arms don't angle into the frame as much, so there is a little more usable space - enough? Don't know yet.
If I could get another 3 inches of droop - get that front wheel in my first picture back on the ground, with the body sitting the same, I would call that a success. The second picture of my truck, you can tell I'm doing my best to force as much flex out of it as possible, and just a little more would have been nice. The 3" that would get me touching in the first picture would not get me touching in the second, and that's fine. Not trying to build a ramp champ, just get that little more out of the system without throwing it all out the door and 3 linking or 4 linking it.
Nice thing about web wheeling is can hash some of this stuff out and see if a theory is worth testing or not.
I think that spring rate/ truck weight is a bigger factor in perceived flex than most realize. It's easy to see how too high a rate will limit compression on the high side but too low a rate hurts it as well.
I have no idea of how to quantify it but my truck has been doing quite well. This isn't the best of pictures but it gives you an idea.
Look at this truck and what it can do. What it has accomplished. 2005's Class 7S Baja 1000 winner Still street legal and registered. Now pay attention to the front axle linkage system. Used to be a 4 link.
Big air
Big Flex
Um Radius arms
FWIW I think the best option for the sway bars is go to a torsion rod style sway bar like the baja trucks and include remote disconnects/reconnects into the system.
Um Radius arms
Im pretty sure that setup is referred to as a Y-link.. Stock Jeep stuff..
radius arms tend to suck at steep climbs because the geometry is not setup for climbing.. properly designed 3-links are better at that, but lets face if folks 80's are bad ass wheelers, but IMO if you need 3-link, you need a Smaller lighter rig more suited for rock crawling.. 80's are way to big for the type of stuff 3 links are good at.. action jackson 3-linked his cruiser and sold it 6 months later.
It would be sweet to see a nice 3 link kit available for those who want to push an 80 that far! with a nice sway bar and proper design it could work :popcorn:
Here's about as Apples to Apples as I can get ya :)
97 w/ OME J springs, L shocks caster plates 35" toyos
93 Slee 4/OME J rear L shocks SLee arms 35" toyo's no sway bars, hitch pin pulled
You can see just how much further I went up this same rock. Our rigs were basically identical in terms of weight. The difference was sway bars, why not the hitch pin? Because mine was on the drivers side so it could only move UP .5" instead of drooping down. So this was all in the sway bars.
Here's the pics :)
Pic #1 97 from the side, notice rear tire in air and position to rock
Pic #2 mine from a slightly different angle, tire on the ground
Pic #3 97 from behind
I don't think you want a swaybar - you want a limiting strap design that provides retention at the end of the shock travel on the corners and allows about 3" of droop in the center. These are relatively easily designed and very cheap - you just need axle mounts. What you achieve is the inability for the entire front end to drop out and unload and resistance on the corners at full droop without hanging the entire assembly off your shock.
Other rigs running 3-links have honed in on this technique to stabilize the front end while allowing the flex without having to upper retain a coil spring and shorten its life. It is a better approach than a swaybar, because a swaybar will not prevent flat out unloading.
The anti-rock bars were designed to prevent "torque jack" in 5-link quad coil short arm Jeep platform, which is where a rear tire just picks up under torque in a flexy situation (this had led some TJ owners to go to leaf sprung rears like the XJ). I don't think that is an issue on an 80 due to arm length and other factors, but I could be wrong.
Outside of the "poor man's" approach, this is what I would do if running a 3-link - while I am no expert by any means, but I think it brings some of the positive features of a leaf spring (progressive resistance to droop) into a flexy coil link suspension.
I really don't want to rely on a suspension component that I expect to flex to also limit that flex if $100 worth of limiting strap would perform that function effectively for me and probably pay for itself several times over in suspension component lifespan.
I've never heard an argument against the limiting strap, and most 4x4 shops seem to carry them, but I guess because it's not "bolt on" you need some fab work to create the axle mounts and most people don't ever get into fabrication.
by Sway bar, i guess i meant something similar to an anti Rock, They make one now that can be disconnected by the turn of a dial.. this would help with body roll and handling on the highway correct?
Any linked suspension should utilize limit straps and bumps!
Ya', but you ever try to stick 5 kids in the back of a 40 series? ;)
I may be wrong, but I'm pretty sure the one that you're talking about with the dial disconnect, does not wholly disconnect the bar. It disconnects part of it so you still have some sway control, just not as much.
Sway bar on a x-link or 3 link isn't a bad thing I don't think, not even off road. What seems to be the fear if you allow greater articulation is that it becomes floppy and uncontroled. A sway bar can be sized to allow full travel yet still keep the suspension from becoming floppy.
Look at it this way -
Stock 80 the articulation is limited
Take the swaybar off the front, you make it so it's easier to articulate it, but the total amount of articulation is still limited by the radius arm set-up.
Take the limit of the radius arm set-up away, and no swaybar, it's possible to be too easy to articulate too much - floppy.
Take the limit away and add back in an appropriate swaybar, you're not as limited as the radius arm, and you're more controled (less floppy) than without the swaybar.
Sure, I meant as an offroad limiting device. I just don't think it is as effective as limiting strap system and certainly more difficult and costly to engineer plus the potential clearance issues with the other links.
Of course, the inherent bind of the radius arms even with the poor man's 3 link might accomplish enough limiting at the corners to just add a center strap to keep it from unloading on the big climbs if you are going to create something of a down travel bias in shock travel (thereby allowing the front end to really drop out) to go with huge meats.
I am really looking at solid front axle baja rigs for suspension ideas.. Mostly the more basic classes of racing and even chase trucks.
It may be asked to crawl from time to time but the majority of its miles will be doing other faster moving things. Winter DD, summer outdoors trips, trails, long distance highway, dabble with rocks a bit. So armor, hyd winch, snorkel, sub tank, long travel, great sways, sub tank etc.
So I will build the suspension around that and include remote sway disconnects so I can get jiggy with the suspension and stay comfortable in my nice leather seat. Rode in a solid axle full size that had a CST long travel suspension complete with bypass shocks. Rode better than stock and handled better than stock even after going from 30.5" tires to 37" tires.
I decided on 315's over the 37x12.5" based on cost. That extra inch is spendy.. Also building around 315's leaves many choices in tires. Could almost throw boggers on a second set of OEM wheels for the price difference. I wont because I'll be getting better shocks instead.
Probably going to run hankook MTs with some siping. Shave the flares a bit and do some light to moderate clearance mods to the inner fender wells. NOT going to give it the bulged fiberglass fender look but have seen some long travel kitted tacos find some room for up travel without them too. On a 80 there wont be a ton but think I can find enough to be worth the effort.
I really think a redesign of the swaybar system should take priority over freeing up the front end. More bar rate and disconnects. You wont notice the improved front sway untill you 3 link but the rear will show the gains. At one obsticle a stiff rear might be need so just disc the front sway so it can level the body and load the front tires forcing the front suspension while the front articulates and goes over. If you had pulled the rear sway too it may have been too unstable at the start like that. A bit later now that the front is'nt working so hard the rear will have to get over it. So discon the rear at that point. Just an example. You can tune a truck to a ramp but unless you have remote sways or something like airbag helper springs with remote pressure control you can not tune the truck to a section of a trail. I think options once you are out getting it dirty are way more important than anything else.
Why is it that everytime improved flex is mentioned, people start talking about ramp champs that aren't set up well? You can take the shocks off completely and probably get the same ramp results, but it's not going to drive the same on the road or trail. Heck, take the springs off you'll probably get some great ramp #'s too.
guess your supose to leave the axles under it to get those great ramp #s thou
yup this is the current state of the truck in the video.
