Used Lift Kit Questions
Riverside, CA
I saw this lift kit for sale locally: Fj cruiser used lift kit.
The guy bought the FJ with it installed and had it removed to put a different kit on- doesn't know how many miles are on it.
Is there a way to check how "worn" the shocks and springs are? Does the FJ use the same springs as the GX and considering that the FJ is lighter? Could I just replace the bushings and bolt the front set onto my GX? Should I stop being a cheapskate and stop browsing CL while drinking?
Thanks all!
I would pass...
Unknown rear springs + what looks like stock FJ Cruiser front springs...along with used Bilsteins w/increased pre-load + strut spacers = Not what you want.
A full set of new Bilsteins is what, $400? ToyTec rear springs, another $200. Sure that's twice as much...but it's all new.
Either way you'll need a rear spring conversion of some sort, as well.
My $0.02
- Brian
I wouldn't run a spacer lift at all. Used can be okay, but aim for something higher up the food chain.
