That's what I've done, but now I'm adding a ARB wiring harness so I get the full effect of the new headlights. I still want to keep the stock parts in case I or someone else wants to go back to stock. Thanks
I think that's a minor problem considering how often you need to change out your headlights. Especially the LED's.I just put H4 conversion lenses in mine, with LED bulbs that have the fan in the back and the little ballast box in line. Everything fit in my stock '68 headlight bucket. The only issue I have is that a bulb change would require removing: bezel, retainer ring, and headlight lens.
Clearance wasn't an issue, here is a stock photo similar to what I have. Also they just plugged into the stock wiring harness...
@Oakley40 Here is what I got, I tried to do it super cheap, so I can report back after a few months if anyone wants me to. I can also post some installed pictures later. I wanted to upgrade the lights, with retaining a stock look. I like the idea of the entire replacement LED housing like Racer62 was selling, but I prefer a stock look. I went with the cheapest H4 housings I could find on amazon (being that the Hella conversion housings were a little pricey). and I just got a set of LED H4 bulbs off Amazon as well.
Here is a link to the housings, they are priced Each, so you will need 2 x $16.36
http://www.amazon.com/gp/product/B001OMEPEU?tag=ihco-20
The bulbs are these:
Amazon.com: 40W 6,000K CREE LED Headlight Conversion Kit 8,000LM Works Underwater Rainproof driver (H4): Automotive
They are plug and play, and will fit in the early style stock headlight buckets.
So far I am pleased. They are bright, they work well, simple plug and play installation, and it was all for under $80. Also you really can't tell that they are upgraded, and they don't change the original look. The only down side is these housings dont have DOT cast into them, so they technically aren't street legal, for that you will need to buy the more expensive HELLA housings.
Hey, it has been great. everything is working like it did when I upgraded it. and yes, they look very close to original.How is this conversion holding up? I really like the stock headlight look.
Thanks
