Upgrade Parts Cache?
The Land of Enchantment
I’m currently starting a ‘72 FJ40 project. Kind of a resto mod thing. I found a guy selling a ‘79 FJ60 parts truck for a good price. The motor is toast but is there anything else I should try to pick up for my 40 project? I’m thinking axles with brakes, power steering, transmission, transfer case? What other parts might be upgrades for my 40?
Do you mean a 79 fj40? Fj60’s started I think in 1980. If a 40, I believe some of the parts may be used to upgrade your 72. Others on here know will chime in I’m sure.
Carb. Dizzy and ignitor.
4 speed, split case, both differentials, complete power steering system, and all the interior pieces guys on Mud are always looking for- - -in other words (if you have the space to store it) everything but the body and frame.
Is the engine an upgrade over the motor in my ‘72 FJ40? Assuming it’s in ok condition? My 40 has the stock motor. I wonder about swapping in the entire engine/trans/tcase. I haven’t seen the truck in person so I’m not totally sure what kind of shape it’s in.
After reading in the FAQs it looks like the mini truck disk brake swap and power steering swap is easier than retro fitting all the FJ60 stuff. This truck will be street and light trails. Conservative suspension and tires 33-35”. Skinny. I have a buddy with a salvage yard I trade with so I can get a mini truck for free instead of paying for the 60.
83-87 were the 60's, 88-90 were the 62's and 91 started the 80's if I'm not mistaken.
The FAQ suggests that you will need an '81 model or later for the split-transfer case. The 3-speed transmission hump will have interference with the H42 4-speed. The H42 has a synchronized 1st gear, aside from that, the J30 is a great gearbox. I'd shoot for an SM420/SM465 if you think that you have the patience fabricating what is needed for the transfercase shifter plate to mount to it. It gets you a semi-serious granny gear, and they are more common in salvage yards. Any transmission swap will likely need driveshaft mods. Aside from a bolt-on power steering pump with the FJ60, a working F is a fine motor.
I'd stick with stock and no bigger than 30s, or an Old Man Emu setup and 31s, only because I've been really out-wheeled by a stock 80's wagon and a really good driver. Learn to fix a birfield on the trail, then consider 35s. Test the flex of the specific lift, then consider 33s; really curved springs don't perform as well as flatter ones.
