- Joined
- Apr 9, 2013
- Threads
- 236
- Messages
- 2,154
Hi Team,
I got stuck in Three Rivers, CA, this past weekend and had my truck towed to Visalia Toyota. The (master) tech there said there was no power to the fuel pump relay, and when he jumped power from the battery to the fuel pump relay it started and ran fine. He ultimately concluded the plug going into the ECU (which sends power to the fuel pump relay) was not connecting well and just pulled it out and reinserted it and they told me they started the truck, it was running fine, and to come pick up the truck.
When I went to start the truck, same problem. After resolving myself to wait for the tech to come back from lunch, I decided to put the key back in and try again. It started three times in a row (I shut it down a few times to test) and sounded fine, so I decided to drive home to Ventura and there it sits in my driveway. After I got home and shut it down I restarted it with no problem.
Other things to know:
- New Denso fuel pump and sock filter within the last 2 years
- New Toyota fuel filter within the last year
- Original fuel pump relay
A couple days before I took it to Toyota on a flat bed it wouldn't start and I checked the 15A EFI fuse, which is fine. At that time I also swapped around the spare EFI relay I have wih the one in the DS kick panel and the new one which is running in the EFI relay in the engine bay fuse box. That is, the truck wasn't starting and after experimenting with swapping the three EFI relays I have in various configurations in the 2 needed slots (engine fuse box and DS kick panel) the truck started fine and ran. I figured I had identified the bad relay by swapping. Then 2 days and 200 miles later it wouldn't start again.
Lastly, I am aware of the area below the ECU (behind the PS knee area speaker panel) where some owners have reported the wiring harness can rub against a metal tab and wear through the insulation, causing shorts. My harness sits off (not touching) the metal tab and per my examination the wiring harness appears never to have touched that metal tab. There are no wear marks at all even on the tape around the insulated wires.
Any thoughts, tip, suggestions would be greatly appreciated. Electrical stuff is not my strong suit so please explain your advice as simply as possible.
Thanks a lot,
Russell
*** Edited 12/8/16 after final solution found - I replaced the fusible link (described below), which initially seemed to have solved the problem. I actually kept a tally sheet on my dash with a pen and recorded 11 instances of successfully starting it after I replaced the fusible link. Then it wouldn't start again, and I went back through it with the multi-meter, bypassing the fuel pump relay, testing the fuel pump relay (FPR), etc. My conclusion then was that my FPR was intermittently failing, so I ordered a new one from Mr. T. After installing the new FPR it has now successfully started 50 times in a row (without a failure to start) over 6 weeks and I have declared the problem solved. Just thought I'd post this for others' benefit.
Intermittent problems are difficult and frustrating, and I'm not an electrical whiz. But I think I got this one licked.
Cheers.
*** Edited again 1/31/23 - The problem never recurred. It's been lots of miles and years, so I'm certain it was the fuel pump relay.
Thanks a lot,
Russell
Cheers.
