Well finally I am done with the rear/front thirds and the knuckle rebuild....with without a hitch.
As some as you know I bought spools. Front was not intentional just the way it went down. I got a chance today to drive it in the field and such. It did very well .
Here is what it did and handled both in grass,tank traps and in some rocks.
No push or pull
I do feel it will be interesting on ice
No bad steering(restriction) while moving. It does feel like I am driving a 71 pig without power steering
. Nothing I cannot live with. NO BINDING....not even a hint.
Bad... I loose a bit of steering while stopped..that is where I WILL NEED STEER ASSIST. Will not be fun in the rocks without it.
I will buy a tapped IFS box and a small ram kit from somewhere. NOT FROM TRAIL GEAR from what I hear.
For those that are looking to spool both front and rear these are the plus's and the negatives. Like me be sure to buy Longfields and Longfield inner axles. Some say to also buy the hub gear from Bobby I would and here is what I would do being it only takes 15 minutes or so to change one.
Put them both in the glove box until needed. Why you ask? My logic is if something is going to give you are far better for that to give on the trail than a Axle or Birf. If something brakes well there you go.....you have 2 on hand.
No push or pull
. Nothing I cannot live with. NO BINDING....not even a hint.Bad... I loose a bit of steering while stopped..that is where I WILL NEED STEER ASSIST. Will not be fun in the rocks without it.
