Unmatched Spare Tire
Valley of the Dirt People, So Cal
Website
forum.ih8mud.com
my 80 is sitting on a new set of 35 inch Geolanders. I have a perfect unused 33 underneath the truck. I don't think a 35 will fit under there. Would it be safe to use it in a pinch? It does not have lockers, so I would think it should be okay, especially if I limited its use to the rear. Any reason it might be a problem to limp to the nearest place (or even home) if needed?
Define safe.
You may not crash, but the tires will rotate at different speeds causing increased wear on the differentials and heat on the viscous coupling. If the VC overheats and seizes, it may be a casualty and then with the center diff seized by the VC, the tires will scuff and wear faster.
Theoretically, if you keep the pressure high enough in the 33...and lower the pressure in the remaining 35s, you could probably get overall tire size to be pretty close. In a pinch, it's probably okay but you'd still have to be careful to not overheat the (possibly) under inflated tires.
My 35 fits in stock location with a Reese hitch, rubs the back Panhard a little but works for me. It just needs a little encouragement....
To get back to town at slow speed? A 33" may do. To get home, you want the tires pretty well matched or you'll have the issues Pin_Head mentioned.
You may be able to sell the "perfect" 33" on Craigslist.
Define safe.
I don't doubt this but I have a question. Why do new vehicles come with a smaller size spare? I know they don't have a VC or locking center diff but I have a hard time believing that a 2" smaller tire would do damage over a few miles. Could it?
...and don't come on vehicles with limited slip diffs.
Plenty safe enough to get you to pavement. Safe enough to get you home if you don't do more than 40ish and keep it under 50 miles or so. I'd worry more about the spiders and pinions (diff pinion, not ring and pinion) than I would be about vehicle stability, and that's what would limit my speed and/ or distance. That diff will be working pretty hard the whole way home...
*edit- the viscous coupler's gonna get real hot, too. I was just reminded of a time when a friend with an '86 4Runner beater had a 2" diameter difference on his back tires and made the mistake of trying out 4WD on pavement. That driveline bound up quicker than you'd imagine, and he had a hell of a time getting it out of 4WD, even after backing up a ways. Since we have center diffs, there won't quite be this issue, but I would assume the VC's not going to be too happy.
There is no way to know if it would cause problems without trying it. Worst thing that could happen is you would have to remove the VC.
I have a 92 so I don't have to worry about a VC. :)
Did you read the VC preventative maintenance thread? That was pretty interesting. Removing the VC doesn't appear to be a big deal, in fact, many have removed it.
Not having a matching spare is for kids who can only afford 4 tires on their Jeep, I always get a giggle at them. It will also keep you off of some club/group rides if they do vehicle inspections. Buy and rotate 5 ties in, the set lasts longer. And yes, a 35 can fit in the stock location.
I think you will find the actual rolling circumference remains the same.
"Hey mister you have a puncture, oh it's ok, it's only flat at the bottom."
regards
Dave
Bah! If you are that concerned about 'overheating the viscous coupler' lock the tcase in Four Wheel Drive.
Eliminate the viscous portion, and drive it slow. Its gonna crow hop around low speed corners with the tcase locked... Like it was mentioned earlier, the outside rolling diameter of the 33 vs the 35 is negligible, much like driving 75+ for miles and miles with one tire 10 or 15 psi low.
the spider gears are meant to take up the differentiation between wheels. Not permanently, but they will take a lot of abuse for a while. Make sure you are current on axle lubricant changes, and just because you skimped on a spare tire does not mean you can skimp on gear lube....cheap guy!! :D
My 35 spare rubbed the panhard bar and was stuffed up against the bumper, and decreased my crappy departure angles even more... I put mine on the roof rack. Its gonna suck when I need to change the tire, as its almost 100# on the roof...but its out of the way, looks cool, and doesn't inhibit suspension movement or decrease off road angles more than necessary.
Side gears and spider gears ride in a steel on steel bushing, so they are not meant for long term and high speed turning. I have seen them worn, scored and galled, but I don't know what it takes to make that happen.
The difference in diameter is about 8%, so the smaller wheel is going to make one extra turn for every 12 of the larger one and the differential is going to split the difference, so about 1 turn for every 24. This isn't much, but the faster and the farther you go the more wear and heat.
I reiterate, reducing the pressure IMO does not alter the circumference of the tyre.
And rather than crow hop or load my transmission, if I was stuck with the smaller tyre for any distance I would dive under and pull a propshaft, 8 nuts and bolts, lock the CDL and call it done.
regards
Dave
Maybe I'm dense, but I'm not getting the math. Wouldn't the rpm difference depend on speed, gearing, etc.?
There will always be a difference in rotational speed if for example one tyre is slightly worn and the other brand new.
Or perhaps you are on a slight curved road where the outer wheel travels a greater distance than the inner, IMO it is more about how long the differential can sustain this without incurring excessive wear. The manufacturer would have to allow for a worn versus a new tyre scenario but, would they have allowed for the difference of rotational speed of a tyre 2 inches taller?
Personally I do not think it would be a big deal if the OP put the spare on and drove 30 miles home, keeping the speed down would help with the heat generated by the spider gears rotating at greater speeds than they are meant to endure.
regards
Dave
