Turbo Kit for Stock Engine
Lodi, California
Hey Guys,
I have a 97 LX that I'm looking to add some power to. Do you know how much horsepower these engines can safely produce with a turbo kit?
I tried to look on ems powered website but it's down. Are they a good company to deal with?
Hey Guys,
Unfortunately they are out of business. Was s sore deal for a lot of people but I gotta admit, at least they offered some goods for a while. There really isn't much out there, but if you do some searching in this section, there are some turbo threads to get educated on. The stock computer can deal with at least a little boost and be reliable, and the power will be at least as good as the no longer available trd supercharger. Good luck.
Awe man. That stinks! Yeah I was looking for the TRD online and couldn't find anything... I'm curious if I could run at 300hp reliably. Thanks!!
300 rw hp easy as from this engine in stock form, providing the head hasnt been machined previously.
I have had 3 turbo intercooled 4.5s and a Vortec V2 supercharged intercooled one as well, and we had 5 boosted 4.5s in the shop just recently, as they get more popular over here. [ some were AXT being fixed......]
I just sold a complete Safari kit I had on the shelf afew weeks ago, and I have a customer who is selling a 300 rw hp 97 80 series turbo intercooled petrol here at the moment as well.
Std computer will only do up to 6 psi boost before throwing a wobbly, and will be aprox 150 -170 rw kw but timing advance will be limited so it wont make as much torque as it should down low.
If its pre 95 model, they are a PITA to do. [I note yours is 97]
If the head hasnt been off, then 10 psi should be possible with a tuning device, which will easily be 300 rw hp on one of these engines.
decompressed with ARP rod bolts and head studs we run up to 25 psi which is more than 300 rw Kw and 1000 rw Nm or more.
To decompress them we use 9:1 pistons [we got 9.3s in Aus] and we use oversize rod bushes and machine the gudgeon bushes in the rod off centre so we can use the genuine head gasket with a ARP Supra head stud kit, and you just have to machine the front 2 to miss the cam bits.
4.5s LOOOOOVVVVVEEEEEE Booooossssssttttt.
Hey Guys,
Smog/Emissions testing where you are? If so, good luck with anything other than the TRD 'kit'.
cheers,
george.
But remember the AU ECU is different than the US ECU. But yes with the proper engine control 300rwhp is not a problem. But as it sits there is no US produced or readily available turbo kits. Maybe one of the AU guys wants to put something together.
Yes, no EGR on our models, no cats, no oxy sensors.
Thats what I would do to a U.S version to turbo it.
Motec have a great low cost unit now we have been using, which would be the best way IMHO.
Otherwise Unichip we use here.
Correct, it is our O2 sensors and closed loop operation that gets us in trouble in the US. Agreed on the Motec setup nice unit to run in parallel with the stock computer, but will run a CEL which will not pass inspection in most emissions locations.
Wow this is getting interesting!! Mine is a 97 with only 99,000 miles. Its registered in AZ and was just smogged. It would be nice to be able to pass smog with it.
I'm trying to justify the cost to turbo and the power I'll get vs a LS 6.2 or Cummins 6BT swap.
So what manifold & turbo are you using to get 25psi & can we see a dyno sheet pleaseeeee.
Do you have a 4wd dyno at the shop? Have you used wolf ems?
There are several turbos you can use, depending on what you want to use it for, and there are several turbo manifolds available cast as well, that will suit a Garret pattern.
We dont have a 4wd dyno, but we do have a shop with one in the street ;)
Scottryana what triggers the CEL ? unichip you can clamp the signal for most things when wiring in and tuning or a oxy sensor signal box for the rear sensor also can cure the CEL, we use them on 4.7 V8s and FJ Cruisers when exhaust and hi flo cats fitted.
Well when you take over the fuel and ignition, there is a return signal that doesn't reach the ECU. It isn't the MAF or O2 that you have to worry about but the actual injectors, you also need to retard timing at the higher boost levels. Yes you could generate a fake O2 signal but at that point there is no need as you are already throwing a CEL.
To do it correctly on a US 80 series for larger boost you need to:
- Change from MAF to MAP as the MAF sensor will be saturated beyond 4.9v
- Take control of electronic ignition advance to reduce timing as boost levels rise
- Be able to control injector pulse width for non-stock size injectors
- Weld in a wide band vs the stock narrow band O2
- And then obviously have some type of boost control.
In my experience, if it isnt cast, and cast well, or a 2 part cast unit, its going to crack......
