rupert14 said:Dusty, could not pass up the opportunity to show everyone your high school ride. Guess you probly have not told everyone here about the last idea you had on how to run a turbo and keep it cool. This time do it by the book. And by the way, get this done right so we can work on how to get some lift and bigger tires on that thing. If not, you will be riding with one of us.
Bob
Dusty said:turocruiser
is the manifold flange that bolts your Safari manifold to the head one long continuous piece of steel plate or is each exhaust port indepandent and not tied together. For example the oe header ports are not tied together by the flange.
You wouldn't have a pic of the manifold would ya?
Ya those guys really are my family
And the out of hood turbo placement realy helps minimize under hood temps
Dusty said:those with forced induction:
The oe fuel pressure regulator has a port that goes to manifold vacum. As forced induction places positive pressure in the intake manifold instead of vacume, what do I do with the tube from the fuel pressure regulator that is suposed to go to vacume?
manifold is at the machine shop being surfaced
Dusty said:I am a little perplexed as to why the truck runs ok under boost with the oe fuel pressure regulator when the oe regulator is designed to increase pressure under vacume. By this logic boost should decrease fuel pressure.
