You are making headway. I could have flanges laser cut if needed. Don't worry about me.
You should install colder than stock spark plugs and close the gap a little. You should also have the injectors cleaned and verify that their distribution is equal. It is only about $10/injector. If you need a place to do it... let me know. If not you could be playing with a ticking time bomb if one is leaning out due to clogging.
To not upgrade the fuel pump and adding probably 100hp isn't the wisest move for only $100 investment when it could melt your engine. n/a is no big deal but forced induction is a science and to not do the basics you could rack up big tab resulting from an uber budget build.
You should for sure put an EGT probe just before the inlet to the turbine inlet in the exhaust manifold and get a boost/vac guage for sure. An air/fuel guage that reads off the stock 02 sensors is not of much use. EGT's are important for tuning under boost.
You may want to also look into alcohol injection as an octane buffer/charged air cooler in addition to your intercooler.
I'm enjoying watching the progression.
Here is some of my madness I built with Buick GN (3.8i 231ci turbo) powered RX-7's. Mid 11's with a stock GN turbo and off the shelf chip:
1st time around:
http://www.v8rx7.com/mark.htm
2nd time doing the conversion:
http://www.wrongmotor.com/gallery/mark_c/index.htm
1st time around:
