- Thread starter
- #21
Now im going on a whole difrent direction on my 3fe. Already have a 86 fj 60 to pull out the 2f block and 4 speed trannyEvery 3FE owners dream
I assume if you run larger injectors you will have to mess with the MAF sensor.
Do you have a wide band O2 with a meter to check air fuel ratio?
I have read about wideband used on 1fz. Didnt iknow the 3fe recognized widebands also ill check it put for a difrent build i got lined up next... now if im not mistaken she will get a programable ECU so O2 sensors and the “barn door” AFM (“maf”) will be eliminatedI assume if you run larger injectors you will have to mess with the MAF sensor.
Wouldnt know what the older AFM barn door “maf” the 3fe has, actually readsDo you know if the MAF takes into account density and flow, or just flow rate? If just flow then you'll likely get it running a bit leaner (hotter) at higher boost.
Would be fun to do an EFI live system with temp monitoring at each exhaust outlet and then you could add in boost pressure adjustment/compensation, but that's a fair bit more technical.
edit: you could add in temp sensor too with somethng like EFI live, and dial it right in, but you may have to increase capacity in your fuel system.
Already done! I didnt understand the fisrt time what you ment... the wideband is what is telling us its dry.You need to put a extra bung in before that cat to read the A/F ratio.
something like this
https://www.amazon.com/AEM-30-0300-Wideband-Sensor-Controller/dp/B0184TSI84/?tag=ihco-20
It does not need to run to the ECU, its a tool to make sure your not leaning out to much and melting down your engine.
programable ecu will be done but until then tryn to make her go as is for a whileMegasquirt?
I’ve seen other turbo 3fe threads on mud, I remember an fj62. Seems like he did the rising rate and a stand alone ecu maybe?
The AFR gauge is neccessary for sure.
Yes a
Look at that beautiful GD thing.After some time in the shop a couple more pics back in her cozy home
View attachment 1892708 View attachment 1892709 View attachment 1892710
Did you use a air fuel ratio gauge?UDDATE!
So after a 3:1 regulator and a wideband we went out for a test drive!
Kept revs under 1.5k for a couple of miles just to see how the wideband behaved. She was reading good mix the whole time.
Decided to go to 3k and... started to misfire!!
Wet muffler!
Guess the 200k HG didint like the 8psi
Edit!
This is still with stock ECU, INJ & everything. Tryn to see how far she does on her own
