Tuffy Security is Interested
:lol::lol:
Actually, I'm going to be mooching your install idea and hit our airframes shop some slow night to bend a little metal and make a one-piece, bolt on version of what you did up.
The no cup holder thing is killing me:frown:
Mooch away. Yeah, I'm actually going to be revising it a little bit. I have a gov't surplus mobile mount for my Toughbook laptop, and what I have planned is a plate that will bolt between the console and the mounts on the floor, basically sandwiching the plate. The plate will have a small horizontal "tongue" that sticks out on the passenger side, to swivel-mount the computer.
Also, there is enough clearance above the rear heater to flush-mount a couple of 12v sockets in the rear "legs". I'm going to install two switched and one unswitched socket back there. Generally every time I have more than one passenger, everybody on board seems to need to charge his cellphone :rolleyes:.
Why not just send them a stock console. As for the armrest height. Run a string from door arm rest to door arm rest and simply measure the distance between this string and the top of the stock console. Viola, correct armrest height and no one is out a cruiser.
I too may be interested if the price is not outrageous, their product has stock size swith holes & holes for 12 volt power outlets and possibly even a rear and/or side outlets for 110V via an internally mounted inverter.
Holes for stock size switches, power outlets and mounting tabs for invertors, radios and CB's would be key in marketing this.
So I stringlined it...the console padded top is 1 3/8" lower than the padded top of the armrests on the 1995 FZJ, so the new unit could be 1 3/8" higher to level things out. I like the way the unit is taking shape. A lot of good ideas voiced here. 12 volt plug holes, cup holders, lockable, wider, cutouts for heater, insulated, 1/2" padded top etc. Let's see a mock up!
... of course it still has to be designed so it keeps the use of the emergency brake handle!!!
This is a great idea as I have mulled the concept as I build my rig for global use and need that extra measure of security. I second the cup holders, laptop storage (15.5" MAC) and power outlets, and making the armrest the same height at the door rests.
***The dual storage is very handy. Ideally I'd like a lockable lower compartment and the ability to swap the OEM top half with the leather surface onto the Tuffy. That would help retain a factory look, keep the comfy leather surface, and keep a very handy second upper storage for pens, pocket knife, business cards, and whatever else you want easy access to without needing to lock it.
As for cost, I have no experience with Tuffy, but I'd only be willing to drop $300 or so for something like this if it can keep a laptop secure from a dude with a crowbar and a few mins time. I understand that it won't be indestructable, but it has to be able to resist entry pretty effectively.
That's about my top wish list, hope this happens, I've seen what some build here, I'd rather have a Tuffy.
Yeah, me too.
Anyhow, check out the list of suggested features in the original post.
I would like
1) Cupholders - Front & Rear.
2) the top of the arm is padded and wider towards the driver. So you don't have to lean over for your elbow to reach it. Of course this extension will have to be able to fold up so that you can use the emergency brake.
I put the 8" into my 80 and have some observations:
1) there is a ton of space below it for mounting stuff if you want to do so. I probably won't as water is a big part of my wheeling and inverters/radios don't like water
2) Adding things like 12v outlets is pretty easy in any tuffy. Just hole-saw and go.
3) A 2nd compartment that doesn't lock is a GREAT idea. The 8" delux has a tiny slot for pens and stuff, but a little bigger for cheap things would be handy. If anything, the main console area is almost too big. I end up having to dig around to find stuff
4) Tuffy is strong. Someone tried to break into mine, used what looks like a screwdriver to attack the lock and tried to pry it up/open as well. They didn't get in. Heck, the lock still works pretty well and it is only $15 or so to get a new lock from Tuffy, which is a pretty good deal too!
Still looking for someone in Colorado willing to volunteer their vehicle.... let me know.
You might widen that to New Mexico, Arizona or Utah - Cortez is about 2 hours closer to Albuquerque then it is to Colorado Springs (6 to 7 hours). How long would they need it for?
I'll find out.
here are some pics of the 8" installed in my 80
you can see that the fancy wood block I used to level things out is... well... a chunk of wood.
I plan to add the cupholders to the back once I paint them, and eventually hope to add some sort of cowling around the wood to pretty it up a little. And/or I'll add something else down there.
another thought: if there were a single cupholder, it could be installed where the factory "cup holder" is- behind the ebrake. should work ok.
Im thinking about fabbing a steel or alum one up with:
-ebrake housed inside and lockable(deterrant to steal a vehicle thats ebrake is on and locked).
-extend the box rearward to accomodate deep cycle battery/batteries and 12v plugs. (would be nice to have all that extra battery weight real low and centered in the vehicle).--ive currently got 2 Lifeline 6volts in that spot and they fit with no issues--135lbs nice and low.
-sized to accomodate small inverter and fan/ventilation for inverter cooling.
-modular to attach to a separate piece in front of unit that would replace the stock shifter tray for added guages/accessories/gps/nav etc.
-modular rearward waterproof box for footwell directly behind console that would contain air compressor etc.
-------any other ideas for things to squeeze in?
I volunteer my 94...
They can have it for however long they need it..
I can drop it off.. I think they are in Cortez?
Great! I'll get in touch with you when I know more. Thank you!
e-brake
I like the idea of an e-brake inside the console but also think the top of the console, (ie the arm rest and subsequent compartment) should extend over the ebrake to maximize space. I always thought there was a lot of wasted space above the e-brake. I think a comparment this size could get a lot of use from me.
Housing the ebrake sounds impractical to me. Last thing I want to do is lift a lid everytime I want to apply the ebrake. A removable lockable lid for the ebrake sounds more practical.
Since we're adding "I'd like to haves," I wonder if there would be a way to incorporate an integral subwoofer without losing too much space..........I know JL audio makes consoles with subwoofers, but I don't know much about them. Also, I too, like the idea of having places to install auxiliary switches......and all of the other items in post #1.
With regard to the concern that only a small(er) number of people might want them, Tuffy should remember that this forum doesn't presume to speak for 100% of 80 owners. I'm confident that there are many more owners, ones who don't even know about this forum, who would also be interested in an upgrade to the factory console
