884.00 canuck plus shipping from Orgeon, Mark does build a nice cage...
I think three sticks of DOM would do it or you could go with HREW which is cheaper..Some people mix, main hoops in Dom and the connectors in Hrew.
DOM vs HREW
There has been a lot of talk about DOM and HREW tubing among off-roading circles and I'll try to answer a few questions that you may have about the differences.
DOM is a process and means "drawn over mandrel". Typically you use DOM when you require precise thicknesses in the ID, OD or wall thickness of a tube. It is not seamless but is made from sheet steel, rolled and electric resistance welded and finally, "DOM'ed". DOM is a cold process. Most typically it is made from low to medium carbon steel.
HREW is cheaper than DOM, but isn't as nice. HREW has a seam weld, as does DOM, but DOM is taken a few steps further to counteract the welding and cold working abnormalities for a straighter stronger piece of tubing. But as far as strength goes for bumpers and sliders, HREW will sufficiently do the job except for applications that require extreme strength.
If I were building a purely competition rock buggy where I would be getting into areas with large drop-offs, I would probably use DOM, but for the kind of off-roading that most people do and even for the occasional rock competition, I would probably go with the HREW.
In summary, DOM is a stronger tubing material than HREW, but costs about twice as much per foot. HREW is more than sufficient for most off-road applications.
