Trollhole's parts swap
The only thing with that is the lack of bows, and then I have to run stock doors. I sold my stock doors already. What do you want for it. They are selling new tops for $450 shipped now from Southboston.
Jeremy
Alright guys, if you are wanting something from IPOR, give Cam a call and let him know you are with UC and are coming to Marshall's part swap and that should get you what you want. If you don't have their number it is (866) 476-6744
You can also PM me(Nathan) or Rockrawler(Terry) and we can add you to the order.
Just to let everyone know that may be looking at this thread and can pass it on.
I personally ( NOT IRON PIGS STUFF ):
1 front FJ-62 front axle built with Longfield Superset, 4.88 gears, ARB Air Locker, complete rebuild kit installed, 92 Four Runner Caliper upgrade with new rotors and wheel bearings ) Axle fully assembled
$1500.00 Too a good homeSOLD
1 Rear FJ-60 Aussie Full Floater with stock axle shafts built with 4.88 gears, ARB Air Locker, with all new bearings, all new brakes installed ) Axle Fully assembled ( This axle also comes with a reseal kit and complete wheel bearing and seal kit not yet installed
$1500.00 Too a good home SOLD
They above axles are not beat they are restoration quality axles ready to be installed. They have not seen Cam's abuse yet!!!
If you buy both $2500.00 for the pair
1 Rear FJ-60 axle set up for spring over with perches for FJ-55 and FJ-60 welded to the axle, comes with 3.73x1 gears and aussie locker and Poly Performance Chromoly axle shafts. Also included is a traction bar adn mounts already welded to the axle. Also includes new brakes and backing plates and 12 lug nuts
Complete for $550 Too a good home SOLD
1 A440F transmission 165k on the ticker and still running great ( no transfer connected ( Transmission only)250$ too a good homeSOLD
1 Split Transfer case separate has rebuild kit already installed will need resealing as it is removed at this time 300$ Too a good home
a bunch of other small goodies that I will be bringing with me not really worth mentioning but please if someone wants any of the above items let me know so I can load them if not they may not make the ride.
I would be interested in the FJ 60 rear with poly axles if you would sell it without the third and aussie. I already have 4.11's and an aussie. I also don't need the brakes or backing plates if you could sell them separately.
Let me know.
Thanks,
Jeremy
I may be interested in the tcase. I am trying to take it to ironman to be checked out now. Hopefully will know for a fact next week!!
I'm swimming in parts. Plus I'm always up for buying something. We so far have a good number of people coming.
i'm in need of a SBC bell housing
needs to be pre 86, fit the 11" flywheel/clutch combo.
prefer 4-5/8 index hole but 5-1/4 will work since AA makes an adapter.
Also need the clutch fork/pivot ball and retainer clip for TOB that fits on the tip of the clutch fork.
i believe most people refer to the bellhousing i need as a "621"
This is all i lack in putting my swap together.
I won't make it to the swap but maybe if someone has it i can get a mudship from someone in the g'vegas or simple'ville area
I'm looking for cheap!
hoping to find one local for about 50 bucks, all my domestic contacts have the same answer "if you would have asked last month, i just threw 3 of them away"
If you stumble on one, you can usually take it off of someones hands for $50. All the ones that I have had to track down were $100. Good luck finding a 621 for $50, or even $100. They are sought after in the hot rod world for T-10's behind big blocks I believe.
Jeremy
$50 is the range i'm looking for. It will probably have to be a truck bell housing to fit the 11" flywheel and i'll have to buy the $40 adapter from AA to make the bearing index fit.
Just parted out a 85 4-Runner in VA. Thinking about coming down with the IPOR guys, or sending some parts. I'm only hauling this stuff if somebody wants it - let me know by Thursday:
Tailgate - a few dents but not rusty. Have both Red and Grey pull handles. Grey carpet. Rear Glass (channel is pretty rusty) I also have two power window assemblies - condition unknown) $60 for all or will separate.
Power Steering Box - Push/Pull $50
4 15x10" Chrome Wheels w/4" BS $40 for all.
Sunroof & Latch $25
Tilt Steering Column $20
Door Panels (dirty, but should clean up) $20
If you are looking for other small parts I might have them - just ask by Thursday. Drivetrain is gone.
Tim
Sunroof & Latch $25
Tim
More Pics:
