For Sale Trollhole 2F Electronic Distributor
I purchased it on June 7th of 2014 so not sure what that means? I believe it is the same ones he is selling now. Maybe he can confirm? I don't believe he sells "large cap" disty's?
I can post some pics if that helps? I will be putting it on ebay tonight with some other parts, including the carb.
trollhole is regarded as better than HEI. its designed for the 40. the HEI is a hack.
he sells both currently last i knew. the small cap has the octane dial below the base. aside from the dial, they function the same.
Is this his older small cap dizzy or the newer big cap one he sells?
Thanks
Big Cap came about on the 2F for FJ-60, and require the dented side cover for the engine. Small cap came on 2Fs in the 40 & 55, even when they went to full electronic. Not sure what year the cut was.
What year engine did you tell Trollhole you were ordering for?
