Transmission won't shift
After putting transmission and transfer back together (I replaced seal between them) the transmission will not shift. Transfer works fine. I did not go inside transmission. Assembly is out of the vehicle. I think I bumped transmission out of neutral when I removed shifter? Ideas?
I did remove cane upon removal of trans/transfer. I put it back in to check operation before re-installing assembly. I have had it in and out several times now. When twisting on transmission force is carried all the way through to output of transfer with little effort so I assume it is in gear.
Thanks FF LC Freak a good light and one flick of a large screwdriver and back in.
Wow, This happened to me today while torquing the transmission output shaft, though I killed the tranny, very puckered.
Thanks for the great tips. Took a while to figure out what the "cane" was and then when I finally moved some parts fore and aft instead of right to left (only thing that would move).
Thanks
