Transmission questions.....
tampa fl
I have a 1993 fzj80. Pulled the engine and transmission. Rebuilt the engine. Its the A442F transmission. My questions is what should i do to the transmission now that i have it out besides clean it? I haven't heard of any body rebuilding these. I don't trust myself to rebuild it. I live in tampa Florida and don't think many transmission shops down here deal with 80s enough for me to trust them. Any help or suggestions would be much appreciated.
nothing really, its basically bulletproof. maybe change the front pump seal while its out. the only things that go bad are easy enough to fix with it in. the solenoids and NSS being the big ones. sometimes other sensors can go out or wiring messed up but i have yet to see anything inside the transmission fail.
^^^^^x2. Don’t fix what ain’t broke. Units are solid!!!!
@satchel If you plan on pulling it all out as one piece as i did the engine hoist leveler makes is possible. Also @OTRAMM makes a crank holding tool helps with the removal and torquing of the crank bolt on the 1fz-fe if you plan on an engine rebuild. Other then that i can't think of anything outside of the norm.
well I hope you did not separate the engine and transmission, and left the TC attached to the flex plate, you should always pull transmission with TC Torque Converter together to not damage the seal or TC shaft I would replace the the seal
I had mine rebuilt in town at a local transmission shop. They didn't report any issues rebuilding it. I haven't finished my install yet though. Should have everything in this weekend. As far as the other posters question about pulling it all. Best tool was the fsm
Very Pretty. Did the shop paint it for you or is just cleaned really good?
Now would be a good time to tear that transfer case apart and install some gears! Thats what i plan to do with mine out.
