- Thread starter
- #21
Transmission filter changed and it solved 50% of the problem
After replacing the transmission filter, and adding new fluid, now all tires spin strongly on all Gears except P and R.
Again, the problem is that the R won't spin backward. It hesitates a little forward then it stops. It seems that 50% issue solved (regarding the tire won't spins issue), but the reverse problem still persists.
The truck tires spin on N as well. The transmission fluid is at the correct level.
When I change Gear between P or R, I can hear a "Kedah" sound. It's not from the break but from somewhere beneath the truck.
Even the truck is in P, I still can spin the tires with my hands.
I cannot move the 4WD gear to N when I change my transmission gear to N. I have to turn off the engine and do that.
If I do that and turn on the engine on the transmission gear in N, and 4WD in N. I will not move the 4WD gear back to H anymore. It has a Grinding sound. The same thing, in this situation, I cannot move the transmission gear to P, as it will also generate a grinding sound as well.
I have the truck on the Jack Stand at this time and Here is the video that documents the steps I tested today.
